Go Back   Boat Design Forums > Design > Propulsion > Props
Old 10-21-2011, 02:09 AM
Laranjo123's Avatar
Laranjo123 Laranjo123 is offline
Naval Architect/Engr. FG
Rep: 17 Posts: 128
Bp series propeller chart
Hello gudday sirs. Where can i find a bp series propeller chart?. Cause mine is very blured?
Old 10-21-2011, 09:22 AM
Rep: 1758 Posts: 1,561
Here, use these and go solve it directly
http://teacher.buet.ac.bd/mmkarim/B_..._Propeller.pdf
or
http://deepblue.lib.umich.edu/handle/2027.42/3557
Old 10-21-2011, 07:55 PM
Laranjo123's Avatar
Rep: 17 Posts: 128
Sir sorry to ask such question but how do i read this graphs....? i have bp=69.15
Old 10-22-2011, 10:50 AM
I don't understand why you would want to use a Bp-Delta chart instead of calculating Kt Kq directly for any wheel. If you have Bp based upon installed power and desired speed, then you will have to check several of the charts to get the best fit blade number and size. By calculating directly you can get a more optimum prop. You already have all the data you need (i.e. torque, rpm and speed) to start optimization.
Anyway, here is a source of Bp-Delta charts for some wheels. With the Kt, Kq data above you could develop your own charts.
http://hem.bredband.net/lagaren/props.htm
So was your question on how to use a Bp-Delta chart or how to convert Kt,Kq and J data to Bp-Delta?
Old 10-23-2011, 12:00 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
I want to know the delta, pitch ratio and the efficiency using the bp. I don't know how to use the BP chart it's my first time to use this...
Old 10-23-2011, 08:29 AM
Adler's Avatar
Adler Adler is offline
Rep: 110 Posts: 98
Advice
Dear,
You can find the method to D.Gerr "Propeller Handbook" Chapter 6 p.66-82.
There is an extended and popular breakdown of Bp-δ method.
Old 10-23-2011, 09:38 AM
Enter your chart with your Bp accross the bottom. Go up your Bp line until you reach the maximum eta (efficency), it is usually marked as a line that curves down left-to-right through the eta curves (think of the eta curves like a topographical map, you want to be on the highest point you can). Use this point to read off your delta (the curves that sweep down from right-to-left) and your pitch ratio (left axis).
I will tell you right now that your Bp is too high for good efficency. Are you using the wake reduced Va? And if so, you should consider increasing the reduction in your gearset. Increasing reduction will make the prop larger and increase the pitch ratio.
Old 10-23-2011, 10:02 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
Yes i did use of that wake..What will happen if i still continue?...
Old 10-23-2011, 10:18 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
Sir what chart which is which? What B do i have to use?...Btw how many blades are involve in this chart?.....
Old 10-23-2011, 11:22 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
Sir i would like to know which is the ( efficiency , delta, MWR, BTF )
The yellow = pitch ratio
the cyan = my BP somewhere there
the violet = bp ranges
red =?
blue ? ( is it the eta? )
red =?
green =?
Old 10-24-2011, 08:48 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
Dear,
Mr.Adler i don't have that book do you own one? Do you mind could you share it to me?...Please
Old 10-24-2011, 09:00 AM
Laranjo123's Avatar
Rep: 17 Posts: 128
Any help people just tell me what B chart do i need and what particular name does those color stands for.?..
Old 12-19-2011, 12:04 PM
Anttey Anttey is offline
Rep: 10 Posts: 7
Now quite the similar topic here. I am at the diameter determining stage. The series is Wageningen.But first I'm suppose to determine the blade number so that I could proceed to Bp-delta chart. I'm asked to determine it from the simmilar type of yachts I'm working on..
Would anyone suggest me the number of blades for a twin screw motor yacht?
L=26.17
B=6.96
T= 1.22
Cb= 0.46
for 30knots iv around 3000HP per screw.
Old 12-19-2011, 12:55 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Start with the lowest number of blades commercially available, find the optimum prop and then perform the cavitation check. If cavitation is predicted, increase the number of blades. Repeat the process until the cavitation check returns an acceptable value.
Cheers
Old 12-19-2011, 01:49 PM
Rep: 10 Posts: 7
Cheers
Thank you.
Cheers
Imperfections--63 Series Verses The 00 Series Compound Tapered Foil Keel viking north Boat Design 3 08-27-2011 07:07 PM
Help with P2-P8 propeller series The Student Props 0 01-19-2011 02:25 PM
Bp delta Kq Kt propeller chart nico Powerboats 2 05-10-2003 08:19 AM
Performance Chart Gades Sailboats 1 04-12-2002 04:00 AM
Performance Chart Gades Boat Design 1 04-12-2002 03:56 AM
