| Bent 60" propeller Hi all I quit lurking to post a question. I recently bought an old tug boat, ex steam built 1890 It has a 3 bladed "Columbian" made in the USA 1961 model bronze propeller D60 P34 inches. I was turning it today and noticed one blade tip is 2” aft off the other 2 blades, so it is bent back, also the leading edge doesn’t match the other 2 blades, it is an inch thick at the tip, leading edge and trailing edge. Questions Can it be bent back by a pro shop or do they have to cut it of and weld it back on? How much should one worry about something like this on a slow turning propeller? P |
| Correcting these defects is a simple poc for a decent propshop. Effects of same defect? Well, depends on rotational speed, but probably most felt as vibration, eventually causing increased bearing/sealing wear. |
| Thanks. Found a decent prop shop and took the prop off today, taking it there tomorrow. P |
| bent s.s rudder post | roscoewalsh | Sailboats | 9 | 08-09-2009 12:20 PM |
| New "disappearing propeller" system for small boats ... | kengrome | Inboards | 4 | 11-13-2007 12:20 AM |
| bent wooden mast | Simon Monard | Sailboats | 5 | 03-10-2005 04:08 PM |
| Bent Keel | lunker | Sailboats | 9 | 08-26-2004 10:11 AM |
| "Propeller pockets" or "Tunnels" | 67-LS1 | Powerboats | 24 | 04-16-2004 06:08 AM |
