Go Back   Boat Design Forums > Design > Propulsion > Props
Old 02-11-2012, 06:31 AM
Rep: 756 Posts: 3,328
"I am interested in speed not more than 12 knots. So is there any modification that I can do."
Reduce the vessels weight by 50% and install 100% to 200% more power.
Going from 8K to 12K is not realistic , but reducing the fuel burn at 8K by 10% might be .
If you MUST have 12K , it will require a different boat.
FF
Old 02-11-2012, 09:20 AM
TrustedShips TrustedShips is offline
Mr.
Rep: 10 Posts: 27
Sadly, all coefficients are above 0.80.... so beyond a certain speed, probably 10 knots, the Resistance curve goes up steeply. Similar ships running at 12 knots have 850 bhp engines. so your figures are right in that respect. My idea was of an alternative modification without touching hull and engine. Can change gear ratio, shaft, propeller.
Devu C.
A Freelancer (Goa, India)
http://trustedships.webs.com/
KORT NOZZLE 19a Brian.Lin Props 0 04-01-2010 01:35 PM
kort nozzle Brian.Lin Propulsion 5 03-17-2010 08:19 AM
Adding extra chines to existing design unseen wombat Boat Design 5 05-29-2009 03:54 PM
Kort nozzle/hull clearance question Quietboats Boat Design 1 09-26-2007 05:23 AM
propulsion of kort nozzle kschung Education 8 09-16-2004 05:28 PM
