Go Back   Boat Design Forums > Design > Propulsion > Props
Old 01-17-2012, 12:00 PM
Dave T Dave T is offline
Rep: 67 Posts: 56
3 blade or 4 blade prop?
I am trying to find some info and opinions on which is better a larger diameter 3 blade prop or a smaller diameter 4 blade prop. I have built an outboard using an 11 horse Briggs [see my thread 11 horse Briggs outboard conversion under do it yourself marinizing]. I ran some rough calculations with the prop calc program from Castle marine and I will need either a larger diameter 3 blade prop or an 8 1/2 diameter 4 blade. To use the 3 blade required I'll need to cut off the cavitation plate and raise it about an inch this I can do if needed or I could go with a 4 blade 8 1/2" that would clear the plate. Is there any advantage to either solution?
Dave T
Old 01-17-2012, 02:20 PM
Richard Woods's Avatar
Richard Woods Richard Woods is offline
Woods Designs
Rep: 976 Posts: 691
I assume you are looking for high thrust, not high speed?
I asked a Honda dealer that question just last week
He said go for the 4 blader. But then Honda is one of the few outboards that come with a 4 blade option.
So I hope someone else answers your question to give an unbiased view
www.sailingcatamarans.com
Old 01-17-2012, 03:09 PM
tuantom's Avatar
tuantom tuantom is offline
Rep: 45 Posts: 177
You're using an 11hp low rpm engine - without getting lost in the details, and if costs are equal, I'd think not having to cut off or modify anything with the 4 blade prop has some weighty advantages right away.
Old 01-17-2012, 05:06 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
For the degrees of magnitude involved here (small) go with the four blade and skip the modification.
-Tom
Old 01-17-2012, 07:22 PM
Rep: 1493 Posts: 7,447
If the diameter is not restricted, three blades will be more efficient.
Old 01-17-2012, 07:31 PM
tunnels tunnels is online now
old one !
Rep: 402 Posts: 1,916
But 4 blades will be smoother running and has a smaller wake !!!
Personally having a outboard and used both 3 and 4 bladed props the 4 blades was the better option and just kept the fully reconditioned 3 bladed prop for a spare under the seat !!
Making beautiful boats is a passion never a chore !
Old 01-17-2012, 08:24 PM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 711
Given that 95% of outboards carry 3-bladed propellors, they must have an inherent advantage. There are 2,4,and 5 bladed options in some cases, but it seems experience has led to 3 being the norm, except in specialty applications.
Old 01-17-2012, 08:40 PM
Outboards have a limited space so four blades often work well. The anti-ventilation plate is the limiting factor.
Old 01-17-2012, 08:46 PM
sabahcat's Avatar
sabahcat sabahcat is offline
Rep: 257 Posts: 793
cheaper to make than 4 or 5 bladers?
Old 01-18-2012, 07:19 AM
They are cheaper and more efficient. A two blade would be even more efficient, but have a bigger diameter and not as smooth running.
Old 01-18-2012, 07:34 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
A 4 bladed prop is only useful where there is insufficient total blade area when sizing a 3 bladed to avoid cavitation. The disadvantage of a 4 bladed is that they are slightly less efficient, you would experience slightly lower rev's at full rack. 3 bladed props also help to avoid resonant frequencies.
A rule of thumb is when changing from 3 to 4 bladed take about 1 inch off the size of pitch + diameter.
Old 01-18-2012, 11:28 AM
Rep: 67 Posts: 56
Thanks for the replies guys. It will probably be about a month before I can get back to my motor projects I want to get my boat and trailer finished first and then I'll run some better calculations.
Dave T
3 blade propeller equivalent to 4 blade 21x14??? yodani Props 10 12-02-2011 07:21 AM
Does a sail act as a turbine blade or a propeller blade? ThinAirDesigns Boat Design 73 01-26-2009 05:43 AM
Prop Blade Twist MattZ Inboards 14 11-08-2008 11:14 AM
5 Blade Cleaver Prop Picture... NautiDesign Boat Design 0 01-22-2008 10:04 AM
2 Blade Hyde Feathering prop FAST FRED Marketplace 0 12-10-2004 05:28 AM
