Go Back   Boat Design Forums > Design > Propulsion > Props
Old 01-23-2008, 05:39 AM
Hisham Hisham is offline
Marine engineer
Rep: 28 Posts: 45
2 blades pedal propeller
Dear All
i am about to start building my first wooden pontoon pedal boat
i know that for pedal propulsion, it is more efficient to use 2 blades propeller
i need a supplier for this type of propellers or
a drawings to make it from wood
help plz????
Old 01-23-2008, 06:11 AM
Previous Member
Rep: 0 Posts: 0
Do you know the hull drag at design speed?
Have you decided on a gear ratio?
Have you a preferred cadence?
Do you know how much power you want design for - how many people, how fit, male or female etc?
Easier to make from steel than wood. You should be able to make one in about 6 hours.
If you provide the above information or enough to allow me to work it out I will give you a prop design.
Rick W.
Pedal Boat Design BG_Geno Boat Design 676 05-23-2009 10:50 PM
2 blades propeller Hisham Boat Design 3 01-31-2008 07:57 PM
SP propeller babakshabani Surface Drives 1 10-24-2007 06:56 AM
wood pedal boat- idea molerocket Boat Design 3 07-20-2006 06:40 PM
propeller plattgatter Marketplace 0 06-13-2006 02:36 PM
