Old 04-15-2010, 09:08 AM
Carlazzomark Carlazzomark is offline
Rep: 16 Posts: 18
New Human Powered/Electric Gear Prototyping
Troy, Michigan, April 12, 2010 --- Marco Polo Boats, Inc. (MPB) of Troy, Michigan, USA, seeks boat builders and human powered boating enthusiasts to test prototypes of a new in-water gear assembly designed for human powered and electric powered boats.
The prototype will be available this summer in four increaser ratios and two torque specifications. The range is intended to serve the leisure, rental, and performance markets.
Qualified testers will be loaned a prototype in exchange for undertaking testing protocols over a 60 day period this summer. If a tester completes the protocol and adheres to program requirements, he or she will be given a gear assembly when production commences.
“Marco Polo Boats is excited about this mechanism and its potential for inexpensive and energy efficient small boat propulsion,” said Mark Vermilion, president of MPB. “We want it tested in the real world by human powered and electric boat enthusiasts so that we can make improvements prior to production.”
Qualified testers must provide their own water craft with front-end pedaling or electric motor, a connecting shaft, and propeller. Optimum input RPMs for the unit are from 50 to 100.
The gear assembly comes in increaser ratios of 1:7 and 1:49 (each with a maximum torque of 157 lb-in), and 1:5 and 1:25 (each with a maximum torque of 200 lb-in).
MPB seeks testing applicants according to the following chart:
Human Powered Category
Ratio Number of Units Max. Torque
1:5 4 200 lb.-in.
1:7 4 157 lb.-in.
1:25 2 200 lb.-in
1:49 2 157 lb.-in.
Electric Motor Powered
1:5 2 200 lb.-in
1:7 2 157 lb.-in.
Interested parties should e-mail testprogram@marcopoloboats.com for program requirements.
--end--
Old 04-15-2010, 06:06 PM
Previous Member
Rep: 0 Posts: 0
Mark
With the electric you would want a reduction ratio.
If you go through some of this thread you get an idea of what people have been doing to get lower shaft speed.
Efficient electric boat
Rick
New Human Powered/Electric Gear Prototyping Carlazzomark Propulsion 5 05-08-2010 04:09 PM
Human Powered Boat SolomonGrundy Boat Design 346 11-10-2009 11:01 PM
Human powered boat gregk Boat Design 0 11-01-2006 09:52 AM
Human Powered Hydrofoil...?? Wynand N Boat Design 2 05-23-2005 03:01 PM
human powered craft nhuber Boat Design 4 07-03-2004 03:45 PM
