Old 11-04-2010, 09:22 AM
WickedGood
Framework for Winter
Lets see some of your design idea for Winter Frameworks to cover your boats.
It was 26 degrees outside last night and I bought a couple big green Poly Tarps to cover the 25 ft Center Console boat.
Just need to make some type of frame to support it from the T top that will hold a few feet of snow without colapsing.
Old 11-04-2010, 09:56 AM
CatBuilder CatBuilder is offline
Rep: 1308 Posts: 3,040
The most stable structure (and decent for keeping snow from collapsing it) is the arch:
Make up some hoops, tie them together along longitudinal rafters, anchor to the ground, and you have a place to store your boat for years.
If snow is a primary concern over windage, the A frame is a good alternative:
Kurt Hughes was right about this place.
Old 11-04-2010, 03:50 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
45 degrees roof angle. Central ridge, straight, I use a 2 x 6 on edge atop two forked posts which are fitted so that they stand up at each end of the boat.
What matters most is that steep angle. Too shallow an angle and the snow could sag in and in a bad winter (snowy) the tarp can get trapped by snow around the boat and then it's impossible to fix and eventually the load could tear the tarp or worse, damage the boat.
Old 11-04-2010, 04:28 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
THIS IS CHEAP AND PROVEN.http://www.by-the-sea.com/stimsonmarine/bowroof.html
Old 11-04-2010, 10:18 PM
Stumble Stumble is offline
Rep: 604 Posts: 1,086
Move somewhere that the water doesn't freeze, keep the boat in the water, sail in January!
Winter LKSD Marketplace 0 09-29-2009 11:51 AM
Winter Project Jim Herbert Boat Design 2 08-29-2009 04:41 PM
Advice on Maine Winter Boat Joshua Gray Powerboats 24 12-20-2007 09:47 AM
Winter Sealant for Bare Wood Hull? TheSound Wooden Boat Building and Restoration 11 10-06-2006 04:58 PM
Winter Storage erie1 Powerboats 6 09-26-2006 04:50 AM
