Old 03-26-2011, 08:19 AM
mjkkemper mjkkemper is offline
Rep: 23 Posts: 16
fiberglass radar arch
just wondering if anyone has built a fiberglass radar arch? If so any pic's
Old 03-26-2011, 08:32 AM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
Here is a pic of one I'm ging to replicate. It is out of wood but a nice design.
Did not come thru will try again. http://www.glen-l.com/ go to customer photos. Click on Bear Cat by Andy Smith boatworks.
Old 03-27-2011, 01:37 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,253
Do you mean something like this?
Old 03-27-2011, 02:03 PM
Rep: 23 Posts: 16
yes
i wanted to see how other people made their plugs or how they did their layup
Old 03-28-2011, 02:39 AM
CDK's Avatar
CDK CDK is offline
retired engineer
There never was a plug.
I made the mold from heavy impregnated plywood, lots of plaster and some silicone. Because I knew that the mold would not survive the operation I paid little attention to prepare the surface: just a single coat of PVA. After the gel coat and three glass layers I embedded stainless tubes in the edges and some pieces of wood to support the upholstery, followed by one last glass layer.
The shape is such that the mold has to be broken over the whole length of one edge to release the object.
Old 03-28-2011, 02:22 PM
Pat Ross Pat Ross is offline
Corinthian 41 Tri #12
Rep: 11 Posts: 48
arch for traveler & main sheet
How do you insure the strength to mount a traveler and main sheet?
Old 03-28-2011, 03:49 PM
Rep: 1493 Posts: 7,447
That's a totally different thing. You will have to start by calculating the structure on the deck where the arch will be mounted to.
Old 03-31-2011, 01:54 PM
Rep: 23 Posts: 16
For a Radar arch I was planning on installing the radar on it
Old 05-12-2012, 05:56 PM
Rep: 23 Posts: 16
Ended up making one and installed it today.
Old 05-13-2012, 06:28 AM
iceboater iceboater is offline
Rep: 113 Posts: 49
Originally Posted by mjkkemper View Post
yes
Thanks for sharing. Could you share with us how you made yours, plug, layup, material?
Axel
Old 05-13-2012, 07:12 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Congratulations mjkkemper, that's looking good.
Probably you'll need to modify the way it is attached to the flybridge, with two contact surfaces instead of one on each side. You won't like the way it swings back and forth on a rough sea.
Old 05-13-2012, 07:33 AM
Rep: 23 Posts: 16
When the aft hard top is added it will avoid this
Below is the plug
Lay up - veil, chop mat and 3 layer of 1708 bi-axle
Wire chase and closing up the inside
De-miles and 3# urathan closed cell added in the chase
Flaring out the inside
Touch up
Old 05-20-2012, 07:44 PM
tunnels tunnels is online now
old one !
Rep: 402 Posts: 1,916
All archs have 4 weak points !the two top 90 degree corners and the two mounts where they are fixed down . Depending on what gets loaded on top and how much weight is there will determin the amout of movement and the forces involved so just be aware !! One line of production boats always had trouble in those 4 places till they changed the design signifcantly .
Making beautiful boats is a passion never a chore !
Old 05-21-2012, 04:45 PM
Rep: 23 Posts: 16
Very interesting and makes good sense. Below is how it's tied inside. 45 degree for lateral support.
The hard top will be about half way up the arch and I would think it would help with the two top 90 degree. Splashing tue so we will see.
Interesting on the new designs. What did they change or improve?
Old 05-24-2012, 06:12 AM
old one !
The upper 90 was broken into 45 and bigger and thicker inside was a pre moulded very stiff glass moulding all on edge completely round the corner , part way along the top and part way down the sides . The bottom one side became a part of a seat back and so tied the whole thing much better !! always vibration but nothing lke it had been !
broaband radar kelp OnBoard Electronics & Controls 4 07-07-2009 08:01 PM
Aluminum arch builder in Florida DeeDee Metal Boat Building 1 10-23-2007 10:32 AM
Aluminum arch builder in Florida DeeDee Sailboats 0 03-24-2007 02:09 PM
Naval Arch. job in Vancouver, BC finavar Services & Employment 0 04-13-2005 07:32 PM
Radar Reflectors SuperPiper Boat Design 4 01-30-2003 05:33 AM
