  #121
Old 01-09-2013, 03:24 PM
garrybull garrybull is offline
Rep: 53 Posts: 153
rear platform is now finished apart from 2 stainless bars to be fitted once there made.
also rod holders are fitted. the 2 centre rod holders are for the bait table to be mounted too.
i'll have the bait table made tomorrow and trimmed up on friday and hopefully fitted.
  #122
Old 01-11-2013, 01:53 PM
Rep: 53 Posts: 153
got the bait table out the mould today and trimmed up and the lloy tubes glassed to the underside.
also trimmed up the stereo pod and got it glassed in place.
  #123
Old 01-12-2013, 01:02 PM
Rep: 53 Posts: 153
stereo pod is now flowcoated over. i went with white flowcoat in the end so it would match the dash.
stereo and speakers all wires up and fitted. sounds great.
the underside of the bait table has now been flowcoated in grey to match the inside of the boat.
im going to get some rubber edge trimming to fit around the bottom edge of the bait table to tidy it up.
  #124
Old 01-15-2013, 10:47 AM
BarbarossaPasha BarbarossaPasha is offline
Rep: 10 Posts: 2
As a new member and a new naval architecture and marine engineering student, I have to say I find this inspiring.
  #125
Old 01-15-2013, 02:15 PM
Rep: 53 Posts: 153
thanks mate.
have not had much chance to do anything on the boat lately due to being busy with other grp jobs.
i have got some rubber edge trim fitted round the wheelhouse roof and around the bait table.
i will also fit the rubber edge trim around the inside of the gunnels too when i get some more.
  #126
Old 01-18-2013, 05:23 AM
tunnels tunnels is offline
old one !
Rep: 537 Posts: 3,748
That what i did for my numberplate and tail light board across the boat i never even unplug it just lift up and out and all the wiring etc and the board goes straight into the boot of my car. Takes 5 second to replace back on the boat !!
Didnt get to go fishing had to many things to do . but did get a good run in the boat . One touch of the switch and again after 12months started straight away!! went for a good run and a few fast places 6400 on the tacho and absolutly flying over the harbour chop and just touching the tops of the chop!! , was such a good a feeling !!
I love yamaha's specially vee 4s !!!!
Making beautiful boats is a passion never a chore !
  #127
Old 01-18-2013, 05:36 AM
Rep: 53 Posts: 153
glad you got to use your boat at last mate.
mines getting closer now but at the moment we got heavy snow and im stuck in doors so no work on the boat today.
next on my list is getting the stainless rails made but im being quoted silly prices which i can't afford for 4 rails.
  #128
Old 02-04-2013, 06:26 PM
Rep: 53 Posts: 153
not much to update really as been busy working on other boats for people.
i have fitted the fuel tank sender in to the stainless tank , wired in a 12v lighter socket on the dash for charging my mobile phone or to power a spot light etc.
the handrails for the boat have now been made and i am collecting them tomorrow morning.
i will have to polish the welds up on the rails as i needed to keep the costs down so that i could afford to have them made.
hoping to have them fitted before the weekend. if not they will be fitted saturday.
  #129
Old 02-06-2013, 01:19 PM
Rep: 53 Posts: 153
all the rails are now temporary fitted.
they need tweaking here and there to get them spot on.
im hoping to make a start on polishing up the welds over the weekend.
  #130
Old 02-06-2013, 07:33 PM
old one !
name ??
last you need the boats name on the side down near the stern !!
  #131
Old 02-07-2013, 01:25 PM
Rep: 53 Posts: 153
all in good time mate.
i want to get everything finished before the decals go on.
want to give the boat a good mop up as well.
  #132
Old 02-17-2013, 02:26 PM
Rep: 53 Posts: 153
well the boat is getting closer to being finished now.
i have now installed AIS radar.
i have put some fuel in the tank to see if the new gauge and sender works and its all spot on.
all i have left to do is mount radar reflector , fit twin horns , fit spot light , polish the rails , couple small hand rails on sides of wheelhouse and get a spare anchor , chain and rope.
then it will need a good clean up ready for sea trials.
  #133
Old 03-14-2013, 01:12 PM
Rep: 53 Posts: 153
not been on for a while as i've been busy working on other boats.
the boat is almost finished now.
just got to re fit the fuel tank and flowcoat out the compartment and the boat should be finished.
i got my rear platform to gunnel grab rails back yesterday and had to get them fitted asap.
i reckon they finish off the back end a treat.
  #134
Old 04-14-2013, 05:07 PM
Rep: 53 Posts: 153
not been on in a while.
boat is pretty much finished now apart from fitting some 90hp carbs when they turn up to turn my 75 in to a 90.
have had the boat out on the water and it recorded 28.9 knots with the 75 and cruised at 21 knots at 4000rpm.
had a little problem with the engine as it started to misfire which turned out to be number 2 coil lead had worked loose from the coil pack.
heres a link to a short video of the boat on the water.
http://www.youtube.com/watch?v=4PhG0jeQLCY
once the new carbs turn up i'll have them stripped and cleaned up and hopefully they will help get me over 30 knots and with a better cruise speed.
  #135
Old 04-14-2013, 06:30 PM
old one !
Just watched the video and really looks good !! well done !!
a couple of baskets in the back filled with fish and that'll make you smile !!
C Raymond Hunt Design, Turbo'd 210 Thread BobBill Sailboats 1 09-15-2011 06:34 AM
Fairey Atalanta Stability Question RHP Boat Design 4 10-23-2009 02:31 PM
Hunt Prpducts LTD ????? SKEBUMZ Open Discussion: All Things Boats & Boating 0 06-06-2009 10:38 AM
Vernon Hunt...???? kitto Boat Design 1 06-08-2007 02:47 AM
Type 3 Hunt Class Destroyers... Sean Herron Boat Design 3 12-04-2006 04:02 PM
