| Tsunami Survival Pod |
| One has to carry it around on his shoulders as he/she moves in the endangered areas, or what? ![]() |
| Standing on top of a hill works really well too, but then you need to survive the aftermath... -Tom |
| A tsunami at sea is nothing --it can even pass by unnoticed . It is when it hits shallow water or land that it manifests destruction. |
| That's one of the most absurd things I've ever seen. Frosty's correct, at sea there's no need for it and if on land, the G forces of being strapped in a 55 gallon drum, being tossed around like a cork, will snap the necks of the occupants. |
| Already got it covered, pax wear helmets with tethers not unlike drag or race cars to avoid neck snapping. |
| I'm pretty sure someone will buy it. |
| The only way I would be interested would be if there were holes in the bottom for me to stick my legs through and walk about. |
| Using a "Hans" devise to prevent rapid head movement doesn't do a thing for your internal origins, which will also slam about, as it's pitched around. These internal injuries are what kill most, in rapid acceleration/deceleration incidents. |
| PAR, it's imho pointless to discuss this thing at any serious technical or operational level. Issues (immediate ones): - one has to be nearby one of these when tsunami hits - one needs to have enough time to get into that coffin, fasten himself, wear a helmet, fasten the helmet, close the hatch and make a prayer - one need to be trained to do the above operations, and should go through drills every so often - it can do nothing for your survival when the mass of mud and debris firmly clamps you to the bottom - will cost a hell lots - you're more likely te die from a heart attack inside one of these than running for a higher ground - you're more likely to survive if you get to a higher ground than if you wait for your destiny inside that stuff - etc. Many other can be found if one just stops and thinks it over. But, as I said, someone will for sure buy that stuff. Probably the same type of persons who spend a fortune to build and equip a high-tech anti-nuclear refuge at their home basements. They make a very small but rich market niche. Well, just like pleasure boaters do, after all. ![]() |
| Either will do . . . |
| It needs to be tested................ I suggest Niagra Falls. I would do what Frosty says put in 2 little leg holes so if you get caught in a whirlpool you can frog kick your way out. Last edited by rasorinc : 07-04-2011 at 05:18 PM. Reason: WRONG forum subject |
| Inflatable collar for survival Dinghy | Unionjack | Boat Design | 34 | 10-08-2011 07:48 PM |
| Survival load on mast or antenna | floating | Boat Design | 3 | 04-30-2011 05:31 AM |
| 30 foot mcgruber 2012 survival sailboat | d lester | Open Discussion: All Things Boats & Boating | 33 | 10-16-2010 03:21 AM |
| Enjoy Survival in disaster | enjoysurvival | Boat Design | 86 | 12-09-2007 08:05 AM |
| Survival story | SeaSpark | Open Discussion: All Things Boats & Boating | 2 | 08-20-2006 06:58 PM |
