Go Back   Boat Design Forums > Community > Open Discussion: All Things Boats & Boating > Press Releases
Old 11-18-2005, 07:10 AM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
second International Conference on High Performance Yacht Design
Timed to coincide with the arrival of the Volvo Ocean Race fleet in New Zealand, the second international conference on high performance yacht design will be held in February 2006, and will showcase the latest developments in yacht research from around the globe. This conference will be a venue where naval architects, engineers, designers and researchers can present and hear papers on the current state of high performance yacht and power craft technology.
Advances in high performance yacht design are being driven by a range of factors, including development of new racing classes and demand for increased size and performance of racing and cruising craft. Radical design concepts such as innovative new hullforms, moving keels and masts and new approaches to sails and propulsion systems require innovative approaches to analysis, design and experimental verification.
Go: http://www.hpyd.org.nz/
Old 01-18-2006, 06:38 AM
atahawaii atahawaii is offline
Naval Architect, P. E.
Rep: 10 Posts: 27
Chris,
Thanks for putting up this notice.
Old 01-20-2006, 06:52 AM
ErikG's Avatar
ErikG ErikG is offline
Rep: 339 Posts: 397
Do you think I would be wrong if a few last minute discussions about canting kells might come along?
Old 01-20-2006, 09:54 AM
Rep: 279 Posts: 524
The latest:
2nd High Performance Yacht Design Conference Draft Programme.
Tuesday
10.30 -12.30
CFD for Sail Design
Kai Graf RANSE investigations of downwind sails and integration into sailing yacht design processes
Karsten Hochkirch Numerical investigation on the effects of trim on a yacht rig
Jin Kim CFD Calculations on the sail-like three dimensional airfoils
Margot Gerritsen The challenging turbulent flow past downwind sails and practical application of CFD to them
1.30 - 3.00
Canting Keels
Ian Campbell Safety considerations in developing the stability and structural requirements in the Volvo Open 70 Rule
Luke McEwen Sink or swing: the funfamentals of canting keel structures
Liz Tier Practical Aspects of Design, Construction and Analysis of Canting Keels
3.30 - 5.00
Tank Testing
Albert Nazarov Experimental research of sailing craft added masses for hull-keel combinations by acceleration tank tests
Magnus Tvete Added Resistance in Short Reflected Waves - Sailing Hull
Giorgio Contento Experimental analyis of the vertical motions in waves of an IACC yacht with calm water-optimized bulb shapes
Wednesday
9.00 - 10.30
Sail Aerodynamics 1
Heikki Hansen An Investigation of Aerodynamic Force Modelling for Yacht Sails using Wind Tunnel Techniques
Philippe Planquart Investigation of the performance of a spinnaker with different appendages - wind tunnel test and numerical simulation
Fabio Fossati Wind tunnel techniques for investigation and optimization of sailing yachts aerodynamics
11.00-12.30
Sail Aerodynamics 2
Peter Richards The Use of Independent Supports and Semi-Rigid Sails in Wind Tunnel Studies
Natasha Erriu Full scale investigation of one-design class catamaran sails
Richard Flay Pressure Measurements on Sails in the Wind Tunnel and in Full-scale
1.30-3.00
Aspects of Performance Prediction
Claudio Fassardi Optimum Sailboat Design by Integrated Parametric Modeling, Performance Prediction and Optimization
Giles Thomas The performance of controllability of yachts sailing downwind in waves
Ulrich Remmlinger Design Process Automation for Sailing Yachts
3.30 - 5.00
CFD for Hull and Appendage Design
Bruce Cartwright Prediction of Motions of Ships and Yachts by Smoothed Particle Hydrodynamics
Sofia Werner A CFD validation test case -wind tunnel tests of a winglet keel
Thursday
9.00 - 10.30
Hull & Rig Structures
Mark Battley Designing composite structures for slamming loads
Andy Philpott Optimal rig design using mathematical programming
Rozetta Payne Knowledge based engineering and INNOVATIVE yacht design
11.00-12.00
Design and Construction
Magnus Burman Energy and Cost Assessment of a High Speed Ship
Patrick Cahill High performance large yacht construction using product data models
The Second High Performance Yacht Design Conference – 14-16 Feb. 2006 dvgale Press Releases 0 03-15-2005 12:00 PM
International HISW Symposium Yacht Design and Construction brian eiland Boat Design 1 07-17-2004 09:28 AM
High Performance Boat design software Kurt Scrudato Software 2 11-02-2003 07:25 PM
