Go Back   Boat Design Forums > Community > Open Discussion: All Things Boats & Boating > Press Releases
Old 07-31-2011, 11:53 AM
windboat windboat is offline
Rep: -9 Posts: 54
Build a power boat, power by wind. PART II
This is a prototype of a boat. wind turbine + battery + electric motor+ hull
= ZEEB, ZERO EMISSION ENERGY BOAT =Tomorrow's sail boat= green boat
needs financial support to complete. welecome positive post & Q , ONLY
Old 07-31-2011, 12:38 PM
rasorinc rasorinc is offline
Rep: 687 Posts: 1,175
Boesch builds classic wood boats in europe. They have an electric one and won an award. Could never find data how long it would run. Months back saw a picture of how many batteries the small boat had but no more. It had LOTS OF THEM.
http://www.boesch-boats.ch/boote/electric-power Correction--click on electric models to see battery banks
Old 08-03-2011, 08:43 PM
Rep: -9 Posts: 54
wind boat , ZEEB, tomorrows sail boat, windturbine electric boat
our boat is similar to the Bosech electric boat, but biger in size,10 times in
weight. So, our spec. is equitable and stand for trial.Our boat use are many,in private yacht aspect.
Green boat Spec: Length 16m Width:3.8m draft:1.3m Height:4.5m(upper deck)10m (main mast), monohull
power: 100 kW electric motor
battery: 108KWH ,i.e. 90 pcs deep cycle batteries (100Ah 12V)=3000KGs
wind turbine : 5kw
Max. v :14kts (estimate)
Range: 14nms~ far
Project total material cost(estimate):US$95,000
Old 08-03-2011, 09:05 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Interesting project.
-Tom
Old 08-05-2011, 02:27 AM
kerosene kerosene is offline
Rep: 175 Posts: 420
just adding link to the previous discussion (last few pages got off track):
Build A Power Boat , Powered By Wind
Old 08-06-2011, 09:40 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
Yet again, a range of 14 nm? You seriously think it is going to sell?
L
Hopefully creating something useful, since 1983.
Old 08-07-2011, 10:23 PM
Rep: -9 Posts: 54
Check the Boesch electric boat, its range will give you the answer.
L
Advice you not to apply max. output all the time. When you drive electric car or boat. It will make the battery die young.
Re the stability of our boat:
boat displacement (rough estimate)=15MT, GM=0.45m
transverse righting arm at inclination 30 degrees=15x0.45xsin30=3.38 ton-m
In case,a gusty wind at 25 m/s ,Beaufort scale 10. The wind drag of mast plus
wind turbine.
mast height(round) = 9.3m ,dia.= 0.3m
pressure on mast=0.07534x25x25x1.2=56.5
drag on mast=56.5x0.3x9.3=158 kgs
drag arm=0.158x9.3/2=0.72 ton-m----------(A)
wind turbine blad area 0.2mx4m long x 3pcs=2.4 msq, turbine case =0.6 msq
pressure on wind turbine and case=0.07534x25x25x1.2=56.5 (this is the turbine stoped ,actual is less)
drag on wind turbine and case=56.5x3=170 kgs
drag arm=0.17x9.1=1.55 ton-m ----------------(B)
(A)+(B)=2.27 ton-m less than 3.38 ton-m,
That is our boat at gusty wind 25 m/S, the inclination will less than 30 degrees.
Old 08-09-2011, 02:31 AM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
Is there anything new or different from what has been discussed here: Build A Power Boat , Powered By Wind ?
What do you mean by
Are the constructive critics and questions not a positive thing for your project?
Cheers
Old 08-09-2011, 04:17 AM
liki liki is offline
Rep: 104 Posts: 169
E.g. 620 Acapulco de Luxe E.P.
* 50kW electric engine
* LiPO battery pack 252V 120Ah (equals Expensive and 30,2kWh
Range
a) 25min/14,5km@35km/h + 6km@10km/h, total 20,5km
b) 45min/18,5km@25km/h + 3km@10km/h, total 21,5km
c) 5h@10-12km/h, total 50km
from: http://www.boesch-boats.ch/boote/ser...electric-power
For this manufacturer's location these boats make sense and the lakes are not big and some, or many, have restricted or unallowed use of IC power.
Old 08-10-2011, 09:28 AM
Lurvio's Avatar
Mad scientist
Rep: 219 Posts: 267
windboat
If you have a 14nm range on a small launch type vessel then why not, it'll probably work. But we are talking about a motor yacht here, the sort vessel that is expected to travel distances that are measured in hundreds of nm. Do you still think someone is ready to pay $500K (more realistic price) for a yacht that can take the owner 14nm at a time and then wait for wind the next several days?
Lurvio
Old 08-10-2011, 09:13 PM
GTS225 GTS225 is offline
Rep: 23 Posts: 32
I'm just an FNG here, but this is incredible. Windboat doesn't care about your calculations or care about whether it works. He cares about getting your money!
Might I be so bold as to suggest we let this thread die?
Roger
Old 08-12-2011, 01:33 PM
Lurvio's Avatar
Mad scientist
Rep: 219 Posts: 267
He'll just make another.
L
Old 08-12-2011, 05:45 PM
Rep: 23 Posts: 32
L
(deep sigh)......Now, how can I argue with that?
Old 09-13-2011, 01:59 AM
Rep: -9 Posts: 54
Vertical axis wind boat
another type windboat:
Old 09-13-2011, 04:12 AM
masalai masalai is online now
masalai
Rep: 1689 Posts: 7,513
Would not sails be cheaper and easier?
But if electric powered drive motors are the desired option, then easily driven hulls configured as in say, a catamaran... A 45 ft cat using "lifepo4" batteries which are charged by wind turbines and PV panels may give you sufficient to travel for several hours using a pair of 10kw motors to deliver 4 to 6 knots in calm seas...
Why do you not do some number crunching from a ONE-TENTH scale model, without the electrical generating stuff, but shore based charging and very accurate energy use recording systems, to work out how many KWH's in energy you will need when scaled up...
I was looking to use a pair of Torqeedo electric outboards of 4KW maximum input - Technology is not mature or robust enough for a reliable cruising lifestyle... If you have a couple of million to spare, get some expert technical help... otherwise enjoy the ride and "accept the diatribe of unbelievers", gracefully...
There are several almost total electrically powered boats about - a splash in the media then deathly silence...
Try to be helpful...
Remember that there are at least two sides for every story...
Build A Power Boat , Powered By Wind windboat Boat Design 203 07-30-2011 11:20 PM
Wave Wind Power with Piezo at electric boat mtumut Boat Design 8 09-07-2009 03:00 AM
New Boat build Power installation Archie1979 Electrical Systems 6 08-29-2008 04:06 PM
Wind Power kach22i Open Discussion: All Things Boats & Boating 4 05-24-2008 04:13 AM
my human power boat build by myself lijunhaoORaj Boatbuilding 3 06-22-2005 09:07 AM
