I/O Trim Problem, please help.
Discussion in 'Powerboats' started by In The Zone, Aug 6, 2005.
  1. In The Zone
    In The Zone New Member
    I have a 1969 Sportcraft 21 footer. The trim on the motor goes up fine and the 1st down cycle fine. The next time I go all the way up and back down it stops an inch short. The next cycle 2 inches short, then finally it gets to where it only goes all the way up to half way down.
    Now if my dad stands on the outdrive it works fine. This is when it's on land, haven't tried it in the water...
    Any idea what's wrong?
  2. gonzo
    Likes: 2,412, Points: 123, Legacy Rep: 2031
    gonzo Senior Member
    What make and model drive do you have?
  3. In The Zone
    Mercrusier Pre-Alpha (R or 1) The boat is a 1968 Sportcraft C-Eagle and the Cylinders have the two lines at the front of the cylinders, not front and back...
  4. gonzo
    gonzo Senior Member
    Have you checked the oil level in the pump?
