Go Back   Boat Design Forums > Design > Propulsion > Pod Drives
Old 02-02-2011, 11:07 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Pod Drives for Displacement Superyachts
I've noticed that a couple of the more recent Mega-Yachts have been fitted with ABB Azipods, but these are all in the 70+ metre class.
Are nthere smaller pod-drives - either diesel electric systems or "direct drives" like the ZF / CMD/ Volvo units - that are designed for smaller displacament craft. I'm thinking in the 40 - 50 metre range, but would be interested in infor on units for smaller vessels as well.
The only stuff that seems to be around is either very small (like the Mastervolt ones) or very large (like the aforementioned ABB ones)
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 02-02-2011, 11:52 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
Will
Funnily enough, we're doing a design with a Volvo IPS drive, smaller 20m boat.
http://www.volvopenta.com/volvopenta...ine_range.aspx
They range from 250 to 850kW
Old 02-03-2011, 04:32 AM
Yes - they've really taken off in the planing and even semi-displacement segments, but there's precious little out there, or so it would seem, for displacement installations.
Of course, the gains aren't there in terms of drag, but there are other advantages... worth a look if nothing else...
Will
www.imaginocean.net
Old 02-04-2011, 02:26 AM
MechaNik MechaNik is offline
Rep: 46 Posts: 92
Hang on, what am I missing here? I thought there were a lot of options on pods for displacement craft in that size range. Just how little power are you thinking of using and the potential speed range?
ABB only go as low as 1MW but they are proactive in yacht supply and offer complete solutions.
Rolls Royce have a huge diversity of solutions with pods ranging from even lower power ratings to the ridiculous side.
I believe there are other suppliers out there too.
Old 02-04-2011, 07:24 AM
apex1
Schottel provides a range of pods, which is not very surprising, did they develop the principle some decades ago.
But the reason that we don´t see pods on smaller yachts is simply that those boats are thought to go remote places and owners like to keep draught as low as possible. (Bermuda restriction)
Just my 2C of course.
Regards
Richard
Old 02-04-2011, 08:38 AM
Rep: 46 Posts: 92
Yes how to forget that originators so quickly and a pretty full range too.
However they do promote their drives for restricted draft. I would think it pertains only to the counter rotating twin prop units vs a conventional single screw?
Old 02-04-2011, 05:05 PM
Thanks Gents... just the sort of links I was after...
Richard... not sure why the draft would be any different to a conventional shaft installation... both would be dictated by the diameter of the prop(s), which would in turn surely be determined by the needs of the particular vessel...? I could well imagine that the pod systems would be limited by the model range of the manufacturers though... but that's just the sort of info I'm looking for.
The downside of course is that they can be vulnerable to damage... and very difficult and expensive to repair... just the same problems as with the CMD / IPS / ZF units...
In terms of power... I would expect that we are looking for the equivalent of a pair of 700 shp shafts... speed is up to 15 knots and displacement probaly around 280 tonnes... all approx
Will
www.imaginocean.net
Old 02-04-2011, 09:10 PM
apex1
Well Will, ........Pun intended
it is not possible to install a pod drive of equivalent power at the same draught of a conventional drive. That was the answer.
All the tricky and finicky snakeoil solutions have at least ONE disadvantage over the prop / shaft design. Commonly one thinks about hull "pockets" of some sort. A idioty.
You are the NA, I am just a boatbuilding clown, get the theories together yourself, its easy. The last leg of the "Z" is the gear, and that is always below a prop shaft level of a conventional.
No pods on yachts.....
Well, my 2c only, of course.
Regards
Richard
Old 02-05-2011, 05:44 AM
Rep: 46 Posts: 92
Will, the first and only pod drive Superyacht I have been on was in about 2002. It was Alumercia from Heesen and it may make a good reference for your project should you continue on that route.
I remember thinking at the time that this must be they way superyachts will go, and surely systems will be better adapted for them. Alas time has proven me wrong and there are still many negatives to pods. Have you seen what they weigh? For a lighter displacement boat as you suggest they may pose more problems than thought of.
If you went to diesel electric they might make more sense, but DE doesn't make sense to me on a yacht either.
Old 02-05-2011, 06:14 AM
Rep: 46 Posts: 92
Actually if your looking for something different why not investigate Voith schneider propellers. They are looking at superyachts to use their full motion control system, for zero speed and under way plus D.P using the main drive.
It would make more sense if you came down on your top speed, but since when have super yachts made sense?
Old 02-05-2011, 07:55 AM
Naval Architect
Indeed they do.
But, if the design, with pods, satisfies the performance and costs issues and the client wants it....why flog a dead horse. You give what s/he wants.
If the units do not meet the performance and costs requirements, then it is a no brainer.
It is certainly not a common sight....doesn't mean one can't do it..if the Will is there...pun intended
Old 02-05-2011, 04:18 PM
Mat-C Mat-C is offline
Rep: 109 Posts: 242
Regards
Richard
Willallison may be an NA, but I'm not... could someone please tell me what this one disadvantage is? The Pod installtions that I've seen - IPS and Zeus certainly haven't suffered from excessive draft - they look much the same as shaft drives to me...???
Old 02-08-2011, 04:43 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Broward built a few 100 footers with pods a few years ago
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 02-09-2011, 03:41 AM
I've been looking into these units a little further. Both Schottel and RR have units that might be suitable.... thanks again for the suggestions.
Draft certainly doesn't appear to be excessive, unless you go for the largest diameter props... in which case the same problem would arise with conventional shaft(s).
As MechaNik correctly pointed out, weight could be more of an issue... the serious commercial units weigh in the vacinity of 5 tonnes, though in the context of a quite large vessel this can almost certainly be accomodated.
Don't get me wrong... I'm not trying to make the case for pods in yachts... but it is the task of the designer to examine all the options... that's all I'm doing at this stage.
Powerabout... I think the Broward installations were for higher speed applications weren't they?
Once again... thanks for the RR & Scottel leads... if there are any others that might make sense, please let me know...
Will
www.imaginocean.net
Old 02-09-2011, 01:22 PM
Rep: 46 Posts: 92
Steerprop is one that supplied a lot of data for a conference I went on for Dynamic positioning. They made some pretty big claims from real life tests using their CRP units compared against open props. Mechanically a CRP pod is more sound than a single blade because of opposing forces in the gear drive. CRP is really what has brought pods back into the light as it is easier to achieve than on a normal shaft.
Top 100 Superyachts 2010 ni-superyachts Press Releases 2 01-14-2010 03:49 AM
Pod boyancy design ddrdan Boat Design 5 06-03-2009 11:42 AM
Transom Pod thostorey Boat Design 4 09-04-2006 09:58 PM
Drafter/Designer - Superyachts lonnie_smith Services & Employment 3 04-04-2005 04:50 PM
advice needed, selling woodworks for superyachts A-Form Wooden Boat Building and Restoration 2 12-24-2004 08:04 AM
