Go Back   Boat Design Forums > Design > Propulsion > Pod Drives
Old 02-09-2011, 04:11 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Based on my research, the CRP units really come into their own at higher displacement speeds and up - so typical yacht speeds. Below that the ducted units are better.
Thanks for the Steerpod link... but a quick google search gets no result... could they be under a different name?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 02-10-2011, 02:45 AM
MechaNik MechaNik is offline
Rep: 46 Posts: 92
Yes I had to change the last post..Steerprop. I had to look it up.
Ducted units could only be better below say 10 knots and are good for higher bollard pull. Open and CRP then tend to take over if suitably sized. A CRP pod is not exactly the same as a CRP shaft with the blades close together, and apparently show some advantages in low speed efficiency and thrust. These units are only good up to 20-25knots unlike Zeus etc units.
Old 02-10-2011, 02:57 AM
Thanks... found them...
RR suggest around 12 knots as the limit for ducts...
As an aside, I watched an interesting youtube clip today of another thruster-powered yacht having an argument with a sea wall or two before eventually running aground onto a reef....
Somewhat befitingly, it was called Unforgettable....
Will
www.imaginocean.net
Old 02-10-2011, 10:05 AM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
Rim Driven Propulsion
To bad our current slow economy has stiffiled more urgent work on these propulsion products:
Exciting New EPS Thruster (& Propulsion)
I was suggesting one application here:
http://www.runningtideyachts.com/dyn...Rim_Drives.php
Old 04-05-2011, 06:09 AM
Tigawave Tigawave is offline
Rep: 12 Posts: 18
OYS have been developing pod drives for smaller vessels, the largest they are currently doing is twin 230hp for the 60m Baltic yachts panamax. Large cast Titanium legs can be lifted and concealed behind hull doors.
http://www.oceanyachtsystems.co.uk/N...ax_August.html
These are making use of the new Maritex bearing material which they will turn in, this has been developed for use in tropics to Arctic with termal expansion close to that of the Al carrier.
Old 07-03-2011, 12:58 AM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 343 Posts: 724
Way back in the 50's I worked for a Marine Design engineer and we made a little "Log Herder" for the timber companies.
It had a Four Cylinder P&H aluminum Diesel and a POD drive. It was a 360 steering device and a real hombre to drive. A young guy would have loved it.
I dont recall any trouble with them.
Top 100 Superyachts 2010 ni-superyachts Press Releases 2 01-14-2010 03:49 AM
Pod boyancy design ddrdan Boat Design 5 06-03-2009 11:42 AM
Transom Pod thostorey Boat Design 4 09-04-2006 09:58 PM
Drafter/Designer - Superyachts lonnie_smith Services & Employment 3 04-04-2005 04:50 PM
advice needed, selling woodworks for superyachts A-Form Wooden Boat Building and Restoration 2 12-24-2004 08:04 AM
