Go Back   Boat Design Forums > Collaboration > Option One
Old 04-15-2002, 01:09 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
Will,
Thanks for putting the numbers down so we can understand them. It's a good illustration of how difficult it is to do comparisons.
Also how easy it is for me to get side tracked. The boat I started this thread with, would be overpowered with this rotary engine.
Are there any other thoughts on O/B vs I/B?
Gary
Old 04-15-2002, 09:48 AM
tom28571 tom28571 is offline
Rep: 1424 Posts: 1,649
Will, Gary & all,
Your posts bring up another important point. It is not just the top speed that we need to be choosing. The performance over the entire range may be even more important to most people. This point is well illustrated by Gary's boat. It is very fast, probably much faster than is needed for a boat intended for cruising and the fuel use figures look very good to me for such a heavy boat. My question is, how does it perform in the transition speed range between displacement and full planing and what is the extent of that range? Gary can answer that question easily.
Although "Liz" only needs 50hp to go 22mph and runs and rides easily at ANY speed in between, some compromise was made to do this. I do not know how much power she would accept or how fast she would go with more power. The compromise in design that was made in the design of the hull bottom makes it possible to run very level with no stern squating as planing is achieved. Unlike all the books predict, the trim angle increases throughout the speed range and is greatest at top speed. I know that top speed would be increased if I could force the trim a bit higher to decrease friction drag, but the longitudinal stability of the hull is too high to allow that with the current setup.
What I have done is to spread the lift further longitudinally than is normal by the chine flats which are at a positive angle of attack relative to the rest of the monohedron planing surface. This positive angle also caused the flats to get progressively wider toward the stern so that their maximum lift is at the the stern. This is my one original fundamental contribution to the design. Actually, I got the idea from thoughts of Weston Farmer from over 50 years ago. Anyway, I compromised some top speed in favor of a better cruising speed range. These chine flats are intended to work like trim tabs to help the boat get onto plane early. The difference is that they don't have the high drag of trim tabs and are, of course, fixed so they can not be lifted as speed is increased.
Apparently, the hydrodynamic lift of the hull does not overcome the lift of the chine flats until a much higher than normal speed is reached, thus the trim angle increase comes much later in the speed range than for "normal" boats.
I don't know how fast "Liz" would safely run with more power but I expect that at some point the tendency for the chine flats to depress the bow would cause handling problems. By using an overpitched prop, I did get up to 25mph and had no problems in smooth water. Probably 30mph or so would not be a problem in relatively smooth water. The chine flats also cause the boat to turn flatter than a normal V hull. Higher power might also cause problems with quick, high-speed turning. To test the safety, I've run through tight high-speed turns but as a caution would not try to treat her like a sport boat.
Designing planing boats is much more demanding than displacement or semi-displacement types and I have much to learn.
Tom Lathrop
Old 04-15-2002, 01:21 PM
Senior Dreamer
Ok, to continue this, I’ll be more specific.
LOA 9m
Beam 2.5m
Displacement (using Tom’s definition) 2000 kg
(Displacement = full cruising weight including all cruising stores, gear, fuel, water and crew.)
Cruising speed 16 kts
Top speed 20 kts
These are targets for my boat. Not to be confused with Option 1, which is still up for debate.
Gary
Old 04-15-2002, 05:52 PM
Willallison's Avatar
Rep: 2283 Posts: 3,468
Tom,
I assume you were actually referring to my boat, not Gary's, but the answer to your question - as I'm sure you already know - is it doesn't perform at all well in the lower speed range. Below about 22 knots the boat wants to fall off plane. Even with 400hp on the back, it struggles even to semi-plane. That is as a result of the way the the whole rig is set up.
But then, that isn't what the boat was designed for - the hull is an adaptation of an early Formula deep-vee, it was built by a somewhat infamous abalone poacher (not me ) so was built in order to carry a heavy load of illegally caught fish as fast as was possible. When we bought the boat (with two older carburetted o/b's which incidentally used almost twice the fuel..) it would do 60mph but would struggle to remain on the plane below about 30. We've altered the engine set up somewhat, so in spite of having much bigger engines (3Litre as opposed to 2.5) we still run a top of around 60mph, but can maintain slightly lower speeds as well. The boat is now under propped in order to achieve this - we estimate that with a light fuel load (it can carry 800Litres), the motors lifted up a bit and higher pitch props we could pull closer to 75mph.
As I said before, I think we need to consider some more basic design objectives before we can decide on what form of propulsion we use. I'll start a new thread on this
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 04-15-2002, 07:17 PM
Thanks Will,
Yes I made a mistake about who's boat I was talking about. It's not a knock on your boat but it does illustrate really well the other end of the performance envelope from where we are interested for a cruising boat. A ride in your boat would be exciting, especially for one just recently lured away (at least partly) from sailboats. I wish we had more input from the other guys on just what speed range we should be interested in. No serious discussion of hull design can be started without that nailed down, or, at least, a desired range which might have to be modified by reality. In many areas where we would like to cruise, your boat would be restricted to low displacement speed by no-wake rules.
While the beam limit of 2.5m has been established, the most important hull dimension for a planing boat is the waterline beam at the hull CG. For one thing it's about the only waterline dimension that does not change at different speeds.
Tom Lathrop
Old 04-15-2002, 07:38 PM
Couldn't agree with you more Tom.
I'm not suggesting we should adopt anything like "Force Eleven" for our coastal cruiser - it makes an excellent coastal cruiser so long as your happy zip from one spot to the next when it's relatively calm. The boat's capable of belting along at 40 knots in just about any weather - its occupants are not!
Will
www.imaginocean.net
Old 05-20-2002, 04:05 PM
Portager's Avatar
Portager Portager is offline
Rep: 322 Posts: 418
Whats the decision?
I read this entire thread, but I still don't know what the conclusion is.
I think the speed selection drives the engine selection. If it is a high speed planing hull it favors outboards, but displacement and semi-displacement favor inboard.
On the topic of single versus dual engines. I have read that 80% of engine problems (at least for diesels) are caused by fuel problems. So having dual engines may be a false sense of security unless you have separate fuel systems and you refuel at separate docks.
Does anyone have data comparing the reliability of inboard versus outboards? While I on the subject what about weight or power to weight ratio and specific fuel conversion efficiency?
The ability to connect auxiliary systems favors inboards, but back-ups are also necessary. I know of diesel heaters/water heaters that provide space heat and hot water directly from diesel fuel. Is there an equivalent gas system?
One option I have seen is to use electric auxiliary heat. This provides heat from shore power when your connected. You can also provide some heat from the battery bank and delay starting the main engine. In addition when you do start the engine it can provide heat and recharge the battery bank.
Cheers;
Mike Schooley
Designing "Portager" a transportable passagemaker
Old 05-20-2002, 06:39 PM
We haven't actually reached a conclusion on this thread yet Mike, discussion will no doubt resume once we have resolved the issue of Option One's speed profile, which is up for review. As you suggest - by changing the desired speed range, we may come up with new requirements for our propulsion system.
As far as auxhillary systems are concerned, there are a multitude of possibilities regardless of which engine package is incorporated. You mention heat or hot water, for instance. I know of a number of local boats - both petrol and diesel - that use gas (as in LPG - do you guys call that butane in the US?) for their heating and hot water. Just an example, but one of many.
Will
www.imaginocean.net
Old 05-27-2002, 04:00 PM
Portager's Avatar
Rep: 322 Posts: 418
Propain
Here is a FAQ page on LPG. http://www.e-lpg.com/product.asp
LPG stands for Liquefied Petroleum Gas and is generally a mixture of Propane (chemical formula C3H8) and Butane (chemical formula C4H10). In some cold areas they adjust the mixture ratio of propane and butane from winter to summer since the boiling point of butane is very close to 0 degrees C and the vapor pressure drops off drastically at low temperatures.
The problem with LPG, propane and butane on boats is the gas is heavier than air so it will settle in the bilge and 1 liter of liquid will form approximately 250 liters of vapor, so it doesn't take a very large leak to create a lot of vapor.
If LPG, propane or butane are stored and/or used on boats then they should be stored in an external locker per ABYC requirements and gas detectors should be provided.
It makes much more sense to me to use the waste heat from the main engine to heat water and the boat and eliminate the propain storage (yes I meant to misspell it) requirement.
Cheers;
Mike Schooley
  #25
Old 05-27-2002, 07:05 PM
This is true for an inboard engined boat - indeed it is for that very reason that I use a methylated spirit cooker and heater on my boat. It is particularly important on petrol (gas) powered vessel where the risk of spark is much greater than diesel engined boats.
But given all this, then how do you go about heating water aboard an outboard powered cruiser? With the high tech nature of modern outboards, I wouldn't have thought that modifying the route of the raw water cooling would be an option.......
Will
www.imaginocean.net
  #26
Old 02-23-2004, 10:01 PM
willibuch3 willibuch3 is offline
Rep: 10 Posts: 12
Outboards on semi-displacement power boats
Originally Posted by duluthboats
For the purposes of this thread let’s assume a boat of 25’- 35’, 4-6K pounds displacement, simidisplacement hull. I hope that doesn’t take all the fun out of it. While toying with ideas for a boat like this, I was convinced that an inboard was the best way to go. I had worked out weight reduction and a simplified drive for a gas or diesel inboard. When it came down to the details, inboards need air intake, exhaust, and cooling water systems. These systems require room and careful placement for them to work correctly. You can make an incredible amount of compromises to allow for these systems. This I think is a very strong reason to use an outboard on a boat of this type.
Gary
I am now building Ted Brewer's 34 ft Quiet Times and plan to power with one of the 4-stroke outboards. Power plans aren't firm but I am certainly 75% convinced that for the reasons you raise it makes good sense. One of the more important factors for me is what I hope will be much quieter operation. I believe the noise reduction will be real for the following:
1. Less vibration because of 6 cylinders on a 100 to 150 hp engine.
2. The engine will be on the transom far from the enclosed cabin where the steering station will be located.
3. The manufacturer's hype indicates reasonable fuel economy but I will have to gain some experience to be convinced.
  #27
Old 02-24-2004, 12:50 AM
hmm....this is a tough one.
The new generation of 4-stroke o/b's are pretty bloody good - quiet, efficient and light. OTH, so are the new lightweight diesel sterndrives that are just coming on to the market - mercruiser make a terriffic little one - about 120hp I think, and the new volvo-penta's look even better. You can also swing a bigger prop, which is something that always concerns me when running o/b's on larger boats. Don't know the weight of the "Quiet Times", or whether Brewer designed it with o/b's in mind - but it would be well worth your while to consult with him on any changes you plan to make to the original plans.
As for noise, I think an inboard (or sterndrive) in a well insulated engineroom will always be quieter than an o/b - though a 'sound board can go a long way to reducing the difference.
Will
www.imaginocean.net
  #28
Old 02-24-2004, 06:08 PM
Will,
I see that this thread did not die completely. I think the best solution to a quiet inbard engine is use CV joints in the drive shaft so that the engine can be isolated on cushioned mounts. On a big heavy boat with huge engine bed stringers it is not as important but, on a lighter boat, it is difficult to absorb the vibrations and they move easily through the whole boat. I like outboards too but would not think them best for a large boat. There must be some point where the advantages of the inboard overcome the disadvantages as size and weight goes up and area of intended use expands.
Tom Lathrop
  #29
Old 02-24-2004, 06:19 PM
Rep: 10 Posts: 12
Ted brewer has provided a supplemental drawing for the outboard installation. I must soon make a decision for or against the outboard since spring is approaching and I will begin setting up the frames soon. The outboard transom frame is slightly different from the inboard frame in that the frame timbers are about 1/2 inch thinner. However, the planking(plywood) is double the thickness of the inboard version.
It seems like so many important things to worry about when building a boat but maybe that is what we enjoy.
Bill(willibuch3)
  #30
Old 02-24-2004, 07:34 PM
Portager's Avatar
Rep: 322 Posts: 418
Ted Brewer's Quite times http://www.tedbrewer.com/power/quiettimes.htm# is a nice looking boat with a full head and nice sleeping accommodations. In a boat that is intended for over night stays, I would want a battery bank to run reading lights and maybe a fan and hot water for the shower. That would lead me to the inboard. On the inboard you can mount any size alternator you want to recharge the battery bank and you can use engine cooling water to heat a hot water tank via a heat exchanger. There is no good way to get hot water from an outboard and the alternator is very limited. If you went with the outboards, then you would also need a generator to heat water and recharge the battery bank. Better to go with a single inboard that does it all.
Regards;
Mike Schooley
Inboard to outboard conversion James Francis Fiberglass and Composite Boat Building 16 06-28-2007 02:46 PM
Inboard to Outboard conversion Crishinor Propulsion 4 06-15-2005 12:05 AM
Inboard to outboard conversion, need help with details. bradmc Boat Design 1 05-11-2005 11:10 PM
Converting inboard to outboard RobCEW Boat Design 7 10-28-2004 03:20 PM
outboard as in inboard? tryin to float Boatbuilding 17 08-12-2004 11:04 AM
