#91
| More Thinks I Think We Agree On Quote:
Enclosed - weather tight Good ventilation Room for mounting instruments (GPS, compass, UHF/VHF radio, optional radar?) Anchor Self draining anchor locker Anchor chain wash (raw or fresh water?) Sea keeping Capable of making short open water passages in good weather and able to survive unexpected changes in conditions. Helm Enclosed - weather tight Good ventilation Room for mounting instruments (GPS, compass, UHF/VHF radio, optional radar?) Cabin Energy efficient lighting Location for small stereo/TV/VCR (I gotta watch the Lakers!) Heater Cockpit Self draining Raw water wash down Fresh water shower Equipment Vented battery bank AGM batteries (spill proof, high charge acceptance) AC battery charger (to recharge off shore power) Fresh water tank DC water pump Pressure accumulator Water heater Cheers; Mike Schooley
__________________ Designing "Portager" a transportable passagemaker |
#92
#93
How about we start on the things we might not agree on? I think the length should be 31'. I'd like to make the length to beam higher to improve efficiency. I select 31' because to go to 32' would require a step up in trailer size with minimal value. I think electrical power should be DC. If you need AC, like for a microwave, then use an inverter. If the builder decides he wants a generator, they could use a small DC generator. Balmar sells a 1.2 Kw DC gasoline generator for $1,995 http://www.balmar.net/PDF/BC00002.pdf 60 lbs, height 14", width 15", length 18". Cheers; Mike Schooley
#94
#95
| I was all ready to join the fray with and catch a few of those darts when I had a rather terminal hard disk crash. - Ironicaly whilst burning a back up disk image onto CD! So alas I am back to square-one of option-1. Will be a few days ! Cheers Paul |
#96
| Our sympathies lie with you Paul......it will give us more time to sharpen the darts! I think the biggest decision we have to make at this point is whether we should go for a head-up, head-down and forward, or raised pilothouse configuration. Pretty much everything else will be based around that.......
#97
| Stability Criteria Quote:
![]() Quote:
I think the raised pilothouse comes down to a stability question. Can you do that in a 8'2" beam? We can guess and speculate or we can do a lot of calculations. What is out stability criteria? How stable is stable enough? Cheers; Mike Schooley
#98
| Boy! Can I put the kibosh on a discussion or what? 4 days without a peep on O1. Must be a record! Or maybe everyone is busy sharpening darts and awaiting Polarities post with baited breath? Will; This is just another nit, but I noticed that you are showing your transom door swinging in and I am showing it swinging out. I think an outee (that's a technical term) is better than an inee because when waves hit an outee it is pushed into the door jam, but waves strike an inee it tries to fail the latch mechanism. The boats that I have seen with transom doors, or all that I can remember, had transom doors that swung out. Cheers; Mike Schooley
#99
) So does the one one my fathers Cheoy Lee - so do most others I can think of. Your reasoning is sound, but it is likely to be more difficult to open the door when on the platform if you've go to swing it out (given the limited space available - you can hardly step back to open the door!) And once latched open a door outside will encroach more on the platform than the cockpit. I'd go for a solid, positive locking mechanism with the door swinging in myself.
#100
| You're right - it is a long time between posts - I was going to put up a poll to decise whether we should have the head up or down, but I was waiting for Paul, Gary and any others to post their ideas 1st......
#101
| I guess my experience is limited to boats with wider swim steps. One thing I like about an outward hinged door is you can put a flap seal on the bottom. Since the flap is trailing outward, wave pressure presses it against the deck and you get very little leakage. With an inward swinging door the pressure forces it open, unless you put the seal on the threshold and then it gets beat up by foot traffic. I agree on waiting for ... but I thought this thread was getting stale. Cheers; Mike Schooley
#102
| sorry guys , working on getting my disk back together! Will have something soonish... Paul |
#103
| PS Will, any chance of getting your hull form in dxf or iges(prefered) ? Paul |
#104
| Just gimme an email address and I'll send it thru Incidentally, I spent a couple of hours at the weekend looking over a 52ft powercat that a guy is building here. It's to be powered by a pair of 220hp Cummins diesels and will cruise at 22knots. With a beam of 5.5m and built entirely of Corcell and multiaxial glass (vacuum bagged) its expected to weigh in at 12500 kg dry. An awesome site to see a guy build a shed, then completely from scratch build such a massive project. The relevence to O-1 is that it reinforces my belief that our boat should be made up wherever possible of developable surfaces. The cat had many areas made up of compound curves and if you could see the amount of work involved in shaping them....! But as a building process, there was nothing being done there that any competent home-builder shouldn't be able to achieve.
#105
| Come on Paul...where are you? I got more darts at the ready than I know what to do with!
