#31
| Extended Cabin Cruiser Quote:
![]() Quote:
O did I say that out-loud? Same comment I had on your previous design I think. Although in mine, only the pilothouse is raised and the galley and head, with their heavy contents, are very low. I think this should compensate for the height of the Pilothouse. The benefit is good 360 degree visibility and a multi-functional space i.e. pilothouse/salon. The fact that my design has evolved to look a lot like "Portager" wasn't lost on me. ![]() Quote:
Although our temps were 26C highs and 20C lows, but I did yard work. I have accumulated a collection of darts, mostly extracted from my backside, and I dying to use some of them.I like your "Extended Cab" cruiser much better than its predecessor, although it is a little too "Clorox bottle" for my taste. I like the ladder access to the fore deck. I was/am trying to incorporate one into my arrangement, but it has to be taller. The angled hatch may be hard to seal. Could you make the seal surface flat? The head looks a little, um, little! What is the headroom in the head? Would I have to sit down to pee? If a head doesn't have standing head room, is it still a head? I like the hardtop/sun roof. It makes the boat lockable and I like the looks better than a soft-top. You might have removable panels that get left on the trailer to secure the aft end. It is nice to combine the helm galley and salon into a large open space, but... I find that underway, people seam to gravitate to the helm. I don't know if it is to distract the pilot or to see where you they are going or both. The Admirable likes to sit across from the me facing forward when it is just the two of us. Also, I don't like people swing pots of hot liquids too close to me when I piloting (we chartered a boat like that once). I guess what I am saying is, for the way I operate my boat, I like my arrangement better. I'm sure you feel the same about yours. In the absence of user inputs we tend to substitute our own desires. It appears that the longitudinal CG will be about at the helm/galley location. Do you have sufficient space for the fuel tanks under the sole? It looks like there is lots of volume under the salon and cockpit but mass placement requirements may not allow you to use some of it. The cockpit seams a little too small. I was trying to allow space for fishing and for two divers to gear up. I think my cockpit is larger than necessary, but yours seams a little too small to me. I like the built-in stairs leading to the side decks. Have you thought about handholds yet? Cheers; Mike Schooley
__________________ Designing "Portager" a transportable passagemaker |
#32
| O1 Outboard OK, here is my O-1 rev 7 with an outboard motor. I added a swim step or boarding platform. I didn't want to shorten the LWL so I kept length and added the platform above. I embedded the outboard into the stern to keep the classic look. Cheers; Mike Schooley
#33
| O1 Inboard ? I know we voted on outboards, but it occurred to me that it would be quite easy to accommodate an inboard engine into the "'raised pilothouse mini-express trawler" so I had to see what it would look like. The red striped boxes are fuel tanks. Shifting fuel between the forward tanks and the aft tank should provide adequate trim control as fuel is consumed. The blue tanks are water tanks. The yellow blob is the Steyr diesel engine scaled to the scale of O1. An with the outboard version, there are transom doors in the stern. There would be a rubber flap at the bottom that will allow the cockpit to self drain, but oppose waves that hit the stern from flowing in unimpeded. Cheers; Mike Schooley
#34
| O1 Stern Drive ? As long as I drew an outboard I figured I might as well do a stern drive version. I shifted the stern drive as far aft as I could to retain as much space in the cockpit as possible. Cheers; Mike Schooley
#35
| If I may!!!! I have no darts to cast. only a few observations. I really have no right to post on this project, but I hope you all do not mind. I think she needs a little more beam up foreward She seems a little needle-like. I think at speed she will be a wet ride. This is a multifaceted + the added flair will create added interior space in the foreward cabin and reserve boyancy in a following swell. If you get cought in some ugly stuff! Back to the foreward cabin. I noticed the cabin sole is very close to the keel and ribs. Dont forget your structural elements. I have fought with this for years I have crammed everything down in the hull so far to keep good stability that I left no room for fuel, grey, black watertanks, batteries and so on! Let alone the very structure that will hold her together. I hope these observations are taken in the right context. Happy noodling! I like the profile and the Volvo DP Outdrive. 8Kts ![]() |
#36
| Thanks Thanks for the comments and compliment. I think they are right on track. Constructive criticism is always welcome. Compliments are even better. ![]() Cheers; Mike Schooley
#37
| Welcome back 8knots - far from being unqualified to speak on the subject we welcome your input - in fact we could do with a bit more....the more the merrier as they say. In fact, how about a couple more of those lovely "1 hour sketches" of yours......
#38
Sorry to hear about your butt, Mike. I feel somewhat guilty that most of those little bruises were caused by darts with my signature on them.... Quote:
Headroom in the head is about 1.7m - not exactly palatial I agree - hopefully I can squeeze a little more in when I (if) I do some more accurate drawings. And no - if it were any less, I think I'd refer to it as the 'shoulder'! Quote:
With a cruise speed in the mid-twenties I don't envisage doing much cooking on the run, so I don't think having the galley helm-side would pose much of a problem. Quote:
From my rough measurements your cockpit is about 2m long (2.6m including the platforms which are more 'external' than mine) and you have 1.4m in front of the outboard well, so whilst it is larger, there isn't that much difference between the two. So far, between just the two of us we have shown at least 4 completely different variations on the same general theme. All have their pro's and con's - perhaps on a single hull, we could offer a couple of different arrangementts......
#39
| Arrangements Quote:
Sorry, I'm a sucker for bad puns. The problem with the head forward is everything tends to stair steps up from there. If you raise the roof on the head it raises everything from there aft. If you move the head aft you have visibility and/or cockpit isolation problems. It seams to me that it all revolves around the head. I think I remember someone telling me that once, but it didn't register.Quote:
By the way, I like your hull form and I was hoping to use it for my arrangement, if it goes forward. ![]() Cheers; Mike Schooley
#40
| Mike, I had a suspicion from the first that you would try to sneak a diesel in under that pilothouse. If that is not your reason, why did you make the pilothouse so high? Excellent visibility can be had with a much lower profile and I'd personally need a really good reason to put up with the up and down of the fore/aft passage. Speaking of visibility and heads, having the head directly behind the helm has minimal effect on steering visibility and avoids the problem choices being discussed. Having the head aft on the opposite side of the helm does have greater effect on helm visibility since the pilot can't stick his head out of the port side to look aft. As mentioned by 8 knots, drawing the interior without reference to the hull shape and structure will surely lead to some problems fitting things in later on. I am still concerned about hulls that are very fine forward and very full aft in following waves. Been there, experienced that , don't like it much. And speaking of fine bows, by the way Will, the Wally boat got some mention in the latest Professional Boatbuilder that came today.
#41
| Not Really, but I wish I could take credit for making the pilothouse that high so that I could put the engine under the pilothouse. In reality, I did the UGLY version first and I needed the height to high to see over the head. When I moved the Pilothouse forward I decided to keep the height the same for visibility aft. You are correct, I could lower the Pilothouse a foot or so but then you couldn't see behind as well. At about 1.5' you would start running out of room for fuel and/or having to shift it some of it forward, which would cause CG problems. As 8knots pointed out, I probably didn't make the pilothouse quite high enough to accommodate the diesel under the sole. I think I need another 6 to 8 inches to make it work. The other problem is the engine is a little too far forward so it is going to tend to be nose heavy. OTOH the outboard will be stern heavy, as would the stern drive. As far as I am concerned the O-1 baseline is still outboard powered. I did the inboard and stern drive versions for my own edification and I welcome comments on them. If anybody objects to me posting them, then I'll delete them. Cheers; Mike Schooley
#42
Of course, with the sterndrive you lose 1/2 your cockpit and with the inboard you've screwed up your weight distribution and no longer have room for any fuel - but then I've been trying to tell you that for ages! He, He, He..... Tom, Quote:
And as I was saying earlier, it also compartmentalises the spaces, making the whole boat feel smaller. Personally - provided adequate headroom can be found without excessive overall height - then I am convinced that the fwd location is best. Quote:
Incidentally, what did you all think of that hullform? Since I posted it, I've played around with the shape a little - giving the mid-hull-side-chine-thingy (which nobody has told me what to correctly call) a little more flare. This should make the boat drier and less prone to burying the bow in a following sea.
#43
I think the main advantage of the outboard/stern drive configurations is the pilothouse could be lower. Tonight I'll try lowering the pilothouse on the outboard (don't think the stern drive is worth the bother) about 8" (one step) and see what that does to the looks. probably need to lower the bow too. The downside will be rear visibility and fore cabin headroom. Quote:
). I was planning to use your hull form, but I need guidance. Cheers; Mike Schooley
#44
| Low Rider? OK, here is the outboard version with the lower raised pilothouse. The height is now 9' overall. I had to lower the bow to make it look better. Headroom in the fwd cabin is now 4' 4". There is also a torturous jog between the pilothouse side deck and the galley/head roof. An unrelated change is I had to narrow the head. I hadn't left enough clearance for the curvature of the hull. Cheers; Mike Schooley
#45
| Here's another variation on the Raised Pilothouse theme. The main salon is of a wide-body configuration, giving excellent internal volume. However, it means you must climb a ladder from the cockpit and go over the salon to reach the foredeck. The raised helm is only a step or two up and contains nothing more than the helm and companion seats. The v-berth is in the bow, with the same foredeck ladder access as before. The heghts need to be played with a bit - the whole thing could be a little lower - though as it is with the salon floor at chine level there is ample room for tankage beneath. Whaddayathink?
