| View Poll Results: Pick a standard... | |||
| Imperial | | 4 | 23.53% |
| Metric with knots and nautical miles | | 10 | 58.82% |
| Completely metric | | 3 | 17.65% |
| Voters: 17. You may not vote on this poll | |||
#121
| Ok I see... Luckless ran out of luck when he replaced your imperial tape with a metric one... Isn't this something you should take up with him personally ? Doesn't seem to have anything to do with the Metric vs imperial thread... Anyway, I'm glad you didn't make the thousand dollar mistake, not that it's much worth from what I hear off late In ZAR it's like nothing... Gets even better in Zim dollars.I have two tapes (Metric of course) and I bloody well never can seem to find any of them. The advantage of course is you cannot make any expensive mistakes if you cannot find the tape can you ![]()
#122
This reminds me of a collossal mistake I saw happen on an oil platform. Two guys had come on board that day and had drawn new measuring tapes from the stores. They were put on a very highly important job of tying-in a riser, that is a pipe coming up from the sea on the platforms jacket, and joining it with a straight pup piece to another pipe already installed on the deck structure. Not a hard job but a very important one as the adjoining three pieces will all have already been hydrotested and once welded and X-rayed they would go straight into service. Well they got stuck in and cut and prepped the fixed ends, then measured the gap, compared sizes and agreed that they had both got the same size. They then cut and prepped the pup-piece and offered it up only to find a sizeable gap. What had happened was that one of the tapes that had been issued to them was marked in feet and decimal feet. Apparently these are used by drillers, I had never seen one in my life and have not seen another since. They must have used that one for their measure and the other ft & ins tape for marking their cut size. There was hell on about it, with many people saying they should have noticed. Needless to say the stores was searched for other similar tapes but none was found. |
#123
| You also get these ornamental things that is some kind of a replica, like a key holder with a tape on it. If it's a toy it can also have faulty measurements on it. Depends what you measure though. In some cases I can imagine you could score a bit like when you measure your 500mm long fish and you see it is almost 900mm in length ![]()
#124
| oh dam decimal feet used by surveyors round here every once in a while when Im laying out benchmarks I have to deal with those what a pain I keep all the decimal equivalents in my nogin but its a pain to have to convert on the fly not hard but just unnecessary might as well be using cubits again or rods and chains |
#125
| I don't think we're taking this seriously enough Quote:
No problem: I choose my own. That’s the beauty of the system, don’t need a tape measure. Quote:
There! I think I got them all. If I missed anyone you can think yourself lucky! ![]()
#126
We never discussed the system that would be used, but some technique was discussed Bit of an exciting time in our otherwise dull existence. I already imagined how I was going to test all the various models... You can't sell something if it wasn't tested and a very braud public opinion was gained, right ![]() Quote:
#127
My tool belt usually carries at least 3 tapes, two matched tapes in the systems the current project is in, and one in the other for if something comes up that needs it. |
#128
| I find cubit far superior than feet in boat building. I have no interest trying to walk along a gunnel of a inverted boat. Feets are actually better suited for walking distances and with some remarks for houses. Span is still the most handy way for mesurements anywhere and it really easy to convert to finger inches. Anything over a fathom is easier to measure with a ones lap Seriously, if anything else except bodyparts is used then the metric is the way to go.. |
#129
Although I am an Imperial supporter, I would use Metric measurements to determine the conversion factors in this instance ![]() |
#130
| If I'm not mistaken, the ****-up happened in Canada when refueling the Boeing 767...correct me if I am wrong.
#131
![]() Ps; Fanie, are you going to the Bloemhof Bonanza end of this month?
#132
| Dunno, almost doubt it. If I do I'll let you know.
#133
| Fanie: in your place, I would certainly insist on assisting with the launch of a new dildo. Teddy: the Inuit have an entire range of dimensions for sizing a kayak to the paddler, using various body measurements. A bit like getting a bespoke suit. Wynand: yes, it was in Canada, land of opportunity to excel in all kinds of things like gliding a jetliner. Recently, that skill got a workout in New York, courtesy of some (Canada) geese, I think. Sorry about that! .
#134
![]() He he... would have worked in inches only ![]()
#135
| Has anyone noticed that many new US movies, like Star Treck and off-spring among others, actually speak in SI units? It would be rather stupid of Spock to say "The Vulcan intestelar ship is 20 millions of stones in weight", wouldn't it. I mean, he would lose all his credibility on the spot... How big is a "stone"? Imperial is stone-age measurement system. |
| Power choice Poll | duluthboats | Option One | 154 | 07-18-2005 02:24 PM |
| New to the metric system | Ron Cook | Boat Design | 5 | 03-03-2005 08:26 PM |
| Portager size Poll | Portager | Boat Design | 1 | 07-22-2003 12:59 AM |
| speed poll | Willallison | Option One | 6 | 06-10-2002 07:13 PM |
| Cruiser design poll... | Polarity | Option One | 37 | 04-11-2002 05:51 PM |
