| Will, I should say that I knew that the Wally is not really a tri hull but at the point where the chine meets the water, it appears to have a similar cross section to a tri. This is my problem with this design as applied to our boat. There is no way to get livable volume in a small boat with this design. The main hull is just too narrow, and like small multihulls it would require a very high superstructure.
| Ah! Now I see where you're coming from Tom. A section of the hull in say the aft 1/3 would indeed resemble the centre hull of a tri. I've obviously not explained my suggestion properly. I'm not proposing that we adopt the Wally hull shape per-say. More that we could adopt a hull with higher angles of deadrise up f'wd to improve its rough water capabilities. True, a very fine entry, like the Wally's, would compromise interior space too much, but I think a balance could be struck to give us a little of both. Here ia few images of the sort of thing I mean. All developable surfaces, with a fine entry, flattening to lower deadrise aft. It probably still carries too much V aft at the moment, but it should demonstrate my suggestion better than I have so far described with words....
| I vote for the S.S. Bathtub method! ![]() |
| For real now I (not a cruiser boat guy) think an Albinish style would look good and sell good. Just my .02 |
| Any other Ideas. Nothing is progressing here much lately in this thread and we need it. |
| developing new 36' C/R, market research ... | lucas adriaanse | Sailboats | 22 | 08-10-2010 06:42 AM |
| Business opportunity offered/Entrepreneur wanted in PROPULSION Market | Hydro | Services & Employment | 2 | 11-10-2006 11:04 PM |
| Yachting market data | jules | Open Discussion: All Things Boats & Boating | 5 | 05-30-2006 12:28 PM |
| Market share. | fcfc | Powerboats | 1 | 05-24-2005 05:22 AM |
| Plans of Bangkok Floating Market type Boats | Boatbuilding | 0 | 09-29-2002 06:54 AM | |
