| Cat or Mono or............................ Here's a poll to solve the hull type. |
| I messed up on the poll and forgot to add it so just post your FINAL choice. There's the options Cat or Mono. After 1 week this will be final. Ok? |
| I really enjoy catamarans, and I would have leaned that way if for example we were designing a boat for weekend hopping. But given the budget and trailerability requirements which limit size, I would probably have to vote for a monohull being the more feasible choice. Cruising for a week means headroom and decent accommodations, and with the budget already sounding tight, I’m not sure that can be done in a 25’-30’ trailerable cat with an 8’-6” beam, especially if we have decided to go for a 30-40 knot top speed. Of course, I would love to be proven wrong! |
| That makes two votes for monos zero for cats........................ |
| I'm afraid that I too must side with Jeff on this one. I don't think that we could meet the performance and trailerability criteria in a way that would make the boat cost effective or pracitcal. If (as I suspect we may shortly be doing....) we were to lower our speed requirements then we might possibly come up with a multihull worthy of consideration. I know it's a little out of left field, but here's a somewhat different approach that I dreamed up. Once again it's only a napkin sketch, so you'll have to forgive the quality. Cats of the sort of dimensions we are looking at are generally of the planing variety. I'm a bit of a fan of the displacement type - this is an attempt to come up with a small displacement cat. The hulls are 12m LOA and can slide in under the main pod (LOA 7.5m) making the vessel 2.5m wide (trailerable). It has comfortable accomodation for 2 + 3. With a pair of 75hp o/b's it should cruise at 20k and top out at about 23. 2 x 50's should see 15 & 19 k respectively
__________________ Will Imaginocean Yacht Design |
| A darn nice concept for a 'napkin sketch' ![]() |
| So three for monos.................................cats well 0 |
| Virtual cat on a virtual napkin... Unfortunately a power cut wiped this out so she's a long way from looking how I'd like. She is absolutely max trailerable beam at 2.5 m. When the lights went out I was just moving the cabin forward .... Paul |
| Monohull I'd also like to vote for a monohull. I think the monohull will sit on the trailer better than a cat and I prefer the ride on a monohull in rough seas. Cheers; Mike Schooley
__________________ Designing "Portager" a transportable passagemaker |
| I rest my case I think this photo makes my point! ![]()
| any objections to the decision for a mono..............If so to bad! |
| Ya, mono. Gary |
| ditto
| Wetted surface area - approximate formulas | Mike D | Boat Design | 11 | 08-25-2005 12:00 PM |
| Looking for a werid power cat | joelhickey | Powerboats | 3 | 06-08-2004 06:06 AM |
| Big Cat, alt CB's & sail rigs | brian eiland | Boat Design | 0 | 10-01-2003 11:41 AM |
| cat hull transom height | hayso | Boat Design | 1 | 05-11-2003 10:17 AM |
| Wetted surface area II: Cat hulls or Monos? | Mike D | Boat Design | 1 | 09-26-2002 12:26 AM |
