Go Back   Boat Design Forums > Community > Open Discussion
Old 12-05-2005, 09:04 AM
dimitriosa dimitriosa is offline
Rep: 10 Posts: 3
ventilation propeller problem
hello
i have an inflatable boat 7,oo meters with a mariner long shaft outboard 200hp.(1996 model)
i recently put a static cmc aluminum braket (9 inch) and i have a problem with my 21 aluminum propeller...when i rich the 5400 rpm its taking air and goes at 6000-6500 rpm....(trim all down)
i have put the engine 7.5 cm highter than before (the bracket) and i CANNOT lower the engine....to fix my problem..
so i either change the motor from a long shaft to an extra long (and iearn 12.5cm )but its an expencive way or i am looking for something else like the permatrim solution (M9?)
i forgot to tell you that i have no trim anymore (when i touch the trim button to rise the motor even 1 cm ,the proptakes air ...or even i turn the boat a litle the prop takes air...)
i thing i need 4 cm lowring the motor to have no problem but i CANT.....)
thank you in advance
dimitrios archolekas
Old 12-05-2005, 11:10 AM
ABoatGuy ABoatGuy is offline
Member
Rep: 39 Posts: 142
You may want to try a "stabilizer plate". It is a flat plate that bolts to the ventilation plate on the outboard. They prevent ventilation. Be careful, they can really change the way the boat handles.
See: http://www.allinflatables.com/shoppi...om/stabil.html
Old 12-05-2005, 12:00 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 933 Posts: 3,638
This is probably far more expensive and complex than you're thinking of, but have you looked at a hydraulic jack plate? Might help get the motor down a bit....
-Matt Marsh-
Old 12-05-2005, 02:52 PM
Rep: 10 Posts: 3
i cant put an hydravlic jackplate cause (i fotgot to tell you that the excaust is really close to the water so i cant get down) its a long shaft motor to an extra long trancom.....
Old 12-05-2005, 03:06 PM
cyclops cyclops is offline
Rep: 24 Posts: 1,057
Why did you put the motor 7.5 cm higher to get a deeper propellor?-------Does the boat look level from outside of it with a normal load or does it ride front down?
Old 12-06-2005, 07:28 AM
Rep: 10 Posts: 3
before the bracket (9 inch back) it was balanced...after the bracket in a calm sea and not running seems to be overloaded back...the excaust hole is close to the sea (4 inches now,,) so i cant go one hole down to earn one inch....
iam afraid of water in the pistons....
i made it to earn the place infront the motor head where i put a refreferator for fishes.....
Old 12-06-2005, 11:07 PM
Rep: 494 Posts: 3,842
Get rid of the bracket, and build a platform over the engine for the fish box.
Old 12-15-2008, 12:39 AM
Captain T Captain T is offline
Rep: 10 Posts: 0
You can take it a wee bit slower, stay on your plane.
Most waste fuel by taking it to WOT or near it, the loss in mph is negligible anyway as long as you maintain a plane.
Put her on plane, back off till you lose the plane, then find the rpm that 'JUST' keeps you on the plane; save mucho fuel and will not eliminate the ventilation, not on turns, but will discourage it big-time.
Cavitation is much more serious, prop damage.
Captain Lee
Underwater Robot Collides with Propeller kach22i Open Discussion 5 11-27-2005 02:11 PM
Surface percing propeller matching problem manunk Props 1 06-21-2005 04:12 PM
bigger props faster ship? Peter H Boatbuilding 18 12-02-2004 07:56 PM
Analytical propeller theory Guest Boat Design 8 11-12-2003 02:57 PM
