Go Back   Boat Design Forums > Community > Open Discussion
Old 08-13-2003, 04:48 AM
steam jet propulsion engines
steam jet propulsion engines...........does anyone know any current info on this technology.....i.e. when will they be manufacturing products?
http://www.pursuitdynamics.com/default.asp
Old 10-10-2003, 01:47 AM
ted655's Avatar
ted655 ted655 is offline
Rep: 105 Posts: 641
As soon as they find a safe, reliable, economical, light weight, fuel eficient steam generator.. Around 2018.
Old 07-04-2004, 02:19 AM
Andrew
How about burning Hydrogen? End result is very very very hot steam. Wouldn't that work?
Old 07-04-2004, 09:01 AM
yipster's Avatar
yipster yipster is offline
Rep: 443 Posts: 2,636
space shuttle main propulsion
Old 07-06-2004, 01:22 AM
Andrew
Haha, there we go. A miniature hydrogen rocket engine for your boat! Does anybody know the volume and pressure of steam required in order to make a boat go anywhere with the proposed (not the rocket engine) steam jet drive?
Old 07-06-2004, 12:00 PM
yipster's Avatar
if your not ganna ask them i might, before you know it they sell it out as fire extinguisher...
from the pulsejet forum "pulsed outboard": "Sorry jets don't push against air or water etc. The propelling force is due to hurling as much stuff away as fast as possible (Rockets work better in a vaccum). As an example jet boats squirt the water from the jet unit out above the water line. The New Zealand built Hamilton jet unit only worked once this was done and of course three people claim to have been the one who sugested the obvious on the vital day." so for boat propulsion i think its a little different beam i guess.
Old 07-07-2004, 09:54 AM
marinedummy marinedummy is offline
Rep: 10 Posts: 11
they are been used sometimes after a gas turbine in a couple of ships the now. rollls royce are looking in to it. i thing its called cogas something
Old 07-08-2004, 06:28 PM
Thunderhead19 Thunderhead19 is offline
Rep: 16 Posts: 500
Actually Hydrogen peroxide and calcium chlorate will generate a healthy supply of superheated steam. Enough to send a several thousand pound projectile across the english channel I seem to recall. They used this process(in that same era) in steam turbines to get experimental u-boats to do over 26kts.
Old 01-19-2005, 10:30 PM
fredrosse fredrosse is offline
USACE Steam
Rep: 20 Posts: 32
Steam Jet Propulsion
I think these are only "pipe dreams"
Old 01-20-2005, 11:45 PM
artemis's Avatar
artemis artemis is offline
Steamboater
Rep: 243 Posts: 410
No, no Fred. First patented in the 1840s by a Frenchman. Called an injector. Using boiler pressure it will pump water into the same boiler. Don't quite understand what these people have to patent though.
Ron Fossum
Old 01-25-2005, 03:56 PM
USACE Steam
Rep: 20 Posts: 32
Pipe Dreams
Steam injectors for boiler feed, as well as steam jet eductors for bilge pumps, boiler ash ejection, and steam jet air ejectors for maintaining condenser vacuum have all been around for more than a century. These devices are used more for convenience (lack of moving parts, intermittent duty) and generally use only a small fraction of available steam on a steam propelled boat or ship.
The reference to the "Steam Jet Boat Propulsion" device as "Pipe Dreams" is in regard to propulsion efficiency by use of such a device. It must be a very very inefficient application of steam power for main propulsion.
The steam jet type pumps are very inefficient to start with, generally being much less efficient than typical small steam engines. They are even less efficient at moving large quantities of water for propulsion.
As we know, decent propulsion efficiency requires the movement of large quantities of water, so the steam jet system seems to have two strikes against it.
Old 01-25-2005, 06:49 PM
artemis's Avatar
Steamboater
Rep: 243 Posts: 410
My remarks were meant facetiously and to point up the absurdity of such a harebrained idea.
Old 01-26-2005, 10:32 AM
yipster's Avatar
you may be rite but nothing wrong with that. allready boats/ships are entering the jet age. turbines and impellors or how will that develop?
reading ion jets and vortex stuff always make me think how that would fit us boaters.
Auto engine marinization DIY Marinizing 227 03-01-2009 07:00 PM
Steam Engines and regulations Dutch Peter Open Discussion 9 10-18-2005 11:15 AM
Jet propulsion possible for slower boat? mik lenoir Propulsion 5 09-24-2005 04:15 PM
Gas turbine/Water jet propulsion peter fisher Open Discussion 1 05-12-2004 09:13 PM
Almost bought prop boat/found jet propulsion may be better SirDooness Powerboats 0 03-31-2004 12:30 AM
