Go Back   Boat Design Forums > Community > Open Discussion
Old 05-25-2008, 06:08 PM
safewalrus's Avatar
Ancient Marriner
Rep: 671 Posts: 4,755
If you see what can happen in a seaway You won't want to ship the boat - best leave it at that!! Same as you never eat in the restaurant AFTER you've checked out the kitchen!!
Old 05-26-2008, 10:09 AM
Spin_Drift's Avatar
Spin_Drift Spin_Drift is offline
Sea Witch
Rep: 10 Posts: 11
OK, got the measurements.
She is 743 centimeters long plus motor which totals to 816 cm
She is 258 cm wide
and 213 cm tall.
I was told she is too wide to go inside a container.
I'm hesitant to ship her tilted as I'm not sure what it would do to the integrity of the boat.
What do you suggest?
BTW, she's been on dry for few years so taking her through Siberia and motoring her through Bering sea is out.
Choose wisely -Treat kindly...
You can put your children and family first and still follow your dreams! I'm a living proof...
When the storm breaks, each man acts in accordance with his own nature. Some are numb with terror, some flee, some hide, and some spread their wings like eagles and soar on the wind...
Old 05-26-2008, 01:10 PM
eponodyne eponodyne is offline
Rep: 150 Posts: 322
I'd look strongly at shipment to the railhead at Vladivostok (if only because that's a place that's fascinated me since I was a child) and thence as cargo. Might be able to work deals as deck cargo on local freighter to Japan and then an oil tanker, as they go out from Alaska laden and return in ballast. Anyway, that route is surely shorter and thus cheaper than across the North Sea, trans-Atlantic, then a Panama Canal transit and up the entire (by definition) Pacific coast of Central and North America. Probably about even with paperwork either way, though.
Old 05-26-2008, 01:27 PM
Fanie Fanie is online now
Fanie
Rep: 893 Posts: 3,229
He he, tilt the container to keep the boat upright
Nice looking piece of driftwood there. I see you polished the camera side of the hull for the picture. I was wondering what the other side of her looks like
If that was my boat, and I want to take her elsewhere, I'd custom built a trailer and tow her out of there... or wait for the next big flood to take it out.
How many trees did you chop and scharf to get her like that ?
He he... What's with the eagle's and stuff on the wind... this is a boat forum
Build the trailer, it may take a day or two but you can always use it over and over... or sell it again.
At least you have control over it
Regards
Fanie
Old 05-26-2008, 06:11 PM
safewalrus's Avatar
Ancient Marriner
Joking aside the trailer is worth a look! then RO-RO port to port, driving in between!! Probably expensive but that's boats!
Alternatively sell her for mucho dinero and build another!! (or is there some other reason involved?)
Old 05-26-2008, 06:20 PM
Fanie
She is 258 cm wide
and 213 cm tall.
That should qualify for trailer transport... not too wide or too high. Most places can issue a temporary license to transport an unlicensed trailer so it shouldn't be a problem.
A hired flat bed trailer could aso work... if you make supports for the hull to sit in.
Regards
Fanie
Old 05-27-2008, 04:18 PM
murdomack murdomack is offline
New Member
Rep: 128 Posts: 201
I was thinking you could do a deal with a shipping company and get her on a flatrack in the hold with one side out about six inches. She could be at the edge next to the hull where they usually leave some space but you would be too high as well, even before you get her onto a frame and this could cause problems and cost as well.
Maybe the trailer on the RORO ship (there are a lot of these around even on ocean routes) is the way to go, but I would talk to shipping companies that go to where you want to get to and see what they can offer. They will all have carried boats before.
Someone will have a suitable service, it's just a case of finding them. It will probably have to be a few separate legs though, with a lot of planning and preparation. You may be best to work the route from Alaska backwards to Finland, do the difficult plan first.
Old 07-16-2008, 10:56 PM
AuxiliaryComms AuxiliaryComms is offline
Master work in progress
Rep: 10 Posts: 64
A thought just occured to me. If you are worried about structural integrity why not build some temporary scaffold inside the boat. The way I would do it (I've never done this before:
Figure out what angle you will have to tilt her to to get her into a container.
While she's still upright, install temporary pillars and cross bracing out of 2x4 inside the hull, at an angle that would make the pillars vertical once the boat was tilted.
Build a cradle to hold her at that angle, narrow enough to fit the container.
Any distortion of the hull would be from the weight of the high side pushing down. With the bracing in place the boat is structured as if the high side was meant to be high.
That may solve your problem without a lot of extra fuss.
At least in my mind this would take the weight of the high side and transfer it through to the cradle. You would want to make sure crade sections and scaffold sections were at the same stations down the length of the boat.
Jason
USCG Auxiliary
FSO-CS Gloucester Point, VA
Support the RNLI (http://www.rnli.org.uk/how_to_support_us)
Support the USCG Auxiliary (http://www.cgaux.org)
Old 07-17-2008, 12:19 AM
Teddy
Rep: 405 Posts: 992
I checked up the boat yesterday and had a pow wow whit Spin Drift.
She has desided to sell the boat. It doesn't fit in a container (not enough flare to fit in tilted) and other means cost fortunes..
Beautiful boat... sad they have to apart..
  #25
Old 07-17-2008, 02:23 AM
masalai masalai is offline
masalai
Rep: 922 Posts: 6,421
How sad Spin Drift, - - Such a beautiful boat... May your deity bless you and help you achieve your hearts desire....
building commenced 23April2009 - - http://boboramdesign.wordpress.com/39-c/
chatter on my build progress . . . http://www.boatdesign.net/forums/boa...-new-post.html
  #26
Old 07-18-2008, 02:24 PM
safewalrus's Avatar
Ancient Marriner
Probably for the best, think how sad you'd be if after carting her half way around the world you open the box and all you find is matchwood! Surely better to leave a thing of beauty like that as just that!
  #27
Old 03-02-2009, 07:09 AM
New Member
Rep: 128 Posts: 201
Here's how you do it with other peoples money
  #28
Old 03-12-2009, 09:45 PM
thudpucker's Avatar
thudpucker thudpucker is offline
Rep: 44 Posts: 391
You might try a company that flies to AK (anchorage) in C-130's on a regular basis. You can get that boat and all the rest of your stuff in a C-130.
Lyndon air Cargo. Based out of Lyndon Washington state.
Shipping costs Maybeoneday Marketplace 2 03-28-2008 12:56 AM
A new Shipping Website. shipdays.com Press Releases 2 08-08-2006 04:12 AM
SHipping overseas pinsk22 Open Discussion 0 02-11-2006 02:02 PM
Shipping a mold Thomas Krane Boat Molds 3 01-01-2005 11:41 AM
