Project progess
Discussion in 'All Things Boats & Boating' started by BHOFM, Aug 26, 2008.
  1. BHOFM
    Likes: 14, Points: 0, Legacy Rep: 247
    BHOFM Senior Member
    I put this here because it's not a serious project!:p :p :p
    Updated daily or monthly or what ever, when I get something
    done!
    Day one:
    Form done and set up.
    I don't think the wind will blow
    it over.
    Day two:
    Mold frames done and chines cut.
    Needs a little bracing.
  2. safewalrus
    Likes: 78, Points: 0, Legacy Rep: 659
    safewalrus Ancient Marriner
    Looks like it could be a nice little project - just remember to takethe blocks out before you 'float your boat' or it may become a submarine!
  3. BHOFM
    BHOFM Senior Member
    Thanks SW,
    I had plans to build a 16' scow, in a nice air conditioned shop!
    With some help! Well, first day, no one showed up, "we" were
    busy! Second day, Well, "There's a car show this weekend"!
    So I am building a 12" row sail, sort of dory, in the driveway
    at home, the shop is nearly 10 miles away!
    I have enough material to build half a dozen of these!
    I can get it in my shop at home once it is off the form, I will
    make a cradle for it on wheels so I can work around it this
    winter!
    Thanks again for your reply!
  4. safewalrus
    Well...............at least your driveway IS airconditioned, sort of! You're getting there - ad most importantly you'e started, nothing like what you intended but your going and tat has got to be good!
  5. BHOFM
    BHOFM Senior Member
    Day 3&4:
    Made the pattern for the stem, laminated a block to cut it
    from!
    Trimmed a bush that was in my way!
    Leveled and braced the mold frames!
    Started the lay out on the keel!
    Transom frame done with temp skin, fitted temporary on
    the jig, it will be planked later, and I mean "planked"!
    Also got all the long pieces cut and planed, battens, sheers,
    chines and enough to do all the stiffeners!
  6. BHOFM
    BHOFM Senior Member
    Day 5
    Wow! Two people looked at this today!
    I'm depressed!
  7. mr curious
    Likes: 1, Points: 0, Legacy Rep: 20
    mr curious gunkholer supreme
    looks very skookum, congrats!
    i see you have moved on from the door fixing... :D
    :cool:
  8. safewalrus
    Wow and time to do a little gardening as well!
  9. BHOFM
    BHOFM Senior Member
    Day 6
    Starting to look like a boat!
  10. masalai
    Likes: 121, Points: 0, Legacy Rep: 1882
    masalai masalai
    BHOFM, Looks like your "signature" must be changed - - this clock maker can build boats..... Keep at it, looking good.....
  11. safewalrus
    Yeah your really going places - well figeratively, not actually YET! But at this rate soon you will! Keep it up mate
  12. BHOFM
    BHOFM Senior Member
    Day 7
    Frame is done!
    Sanding planing and checking is next!
    Boat talk,, Fair the frame!
    ARRRRRRRRR Matie! Shiver me timbers!
    I really like the gentle lines of this little boat!
  13. BHOFM
    BHOFM Senior Member
    I didn't say you couldn't, I said you shouldn't!
  14. masalai
    masalai masalai
    OK , how about - - - - "but candidly, this clock maker can and did....."
  15. safewalrus
    All going as smooth as clockwork then................whoops, well you know what I mean! She's looking good
