| best hull design for high speed boat please help in choosing the design of the best and fast boat so please tell me which design is the best........... |
| Are you sailing, or powering? Are you doing this in calm, flat water or in rough water? How much "stuff" do you want to carry? For what distance do you want to be able to travel at high speed? Do you want comfort as well? Cheapness? Good looks? ![]() And, last but not least, how much do you plan on spending on this boat? All the above will have some bearing on what is the "Best" hull for the job. Steve |
| reply i am powering calm, flat water not too much stuff short distance the cost does not matter |
| Then you need this one ![]() (wouldn't hurt to hire the driver, either...) http://www.kenwarby.com/introduction.htm Steve |
| What do you mean by "best"? |
| i want to design a fast boat but i am not sure about the hull shape yet. i want to decide which hull shape is better than the other based on calculation and data. this design is for salling not for powering Last edited by mn4050 : 07-01-2004 at 06:59 AM. Reason: missing informatiom |
| Go with a Cat.
__________________ Slippery when wet. www.cheetahcat.com |
| Use a sailboard |
This is good for glass flat water, though the first wave will knock your teeth out. |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 04:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 06:48 PM |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 07:01 AM |
| Concept Boat Design Contest | Tad | Boat Design | 16 | 09-17-2004 10:13 AM |
| Rudder design for solar boat | lost at sea | Boat Design | 9 | 01-26-2004 11:39 AM |
