Old 09-03-2009, 08:56 PM
jdmsijdm jdmsijdm is offline
Rep: 13 Posts: 17
Wiring up yamaha 30
Ok so i got an OMC control box with a 10 pin red plug at the end, looks like this:
And a 30hp yamaha with no harness, but a bunch of cut/disconnected wires that look like this:
So my question is, which wires do what? I plan to buy a plug tomorrow that will match up to my control box, but ill still have to match up the wires. Are they universal across brands? Or anyone have a yamaha schematic? Its a 1990 3 cyl.
Any help would be appreciated.
Old 09-03-2009, 09:25 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
The wiring pinouts of control boxes and outboards are nowhere close to universal across brands.
You should be able to figure out which pins on your control box map to which functions by tracing the different colours, or with a multimeter and some patience.
You might be able to figure out a couple of the outboard's wires by following them back to the component at which they end, but a bunch of them will likely lead back to one of those hermetically sealed boxes- a shop manual for 1990 Yamaha 3-cyl outboards will be a worthwhile purchase.
Old 09-04-2009, 02:42 AM
WotEver WotEver is offline
Rep: -15 Posts: 33
<snip> a shop manual for 1990 Yamaha 3-cyl outboards will be a worthwhile purchase.
These folks might be of some use.
Tony
Old 09-04-2009, 04:10 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,144
Go to yamahaoutboardparts.com and copy the wiring diagram for your engine.
They have drawings of all Yamaha marine products ever made.
For the OMC control unit it is less simple. Use a multimeter like marshmat suggested.
Old 09-04-2009, 11:48 PM
Rep: 2891 Posts: 8,792
There are two types of people in regard to these sort of things; those that don't like to do it, but certainly can and those that really shouldn't, because they don't understand why they shouldn't. You are one of the latter. No insult intended, but you just lack the expertise to track down the few simple circuits to get the basics of the engine operational. Getting a wiring diagram shouldn't be questioned, though not totally necessary if you are reasonably familiar with these types of things. The brown wire in the center of the last image is obvious or it should be to someone trying this, if not get some help.
Old 09-05-2009, 12:24 AM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
I got all the yamaha manuals here with wiringdiagrms and some omc stuff ......but no model no or year ????? my mind reading days are over ...
If you were electrically orientated you would just work it out ...but remember as you are not that the ignition switch shorts out the ignition and does not turn it on/off
Be cool but not Frosty
Old 09-05-2009, 07:32 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1930 Posts: 4,195
You can also find someone with a similar motor to your's, see where the wires goes. Most of those motors have the same wiring.
Regards
Fanie
Water ! Just gimme water !
Old 09-06-2009, 01:55 AM
pistnbroke's Avatar
I try
like I said I got all the diagrams which motor is it .....year model\\\
Stay cool not Frosty
Old 09-06-2009, 02:09 AM
He says it's a 1990, 3 cylander, 30 HP, but you're right which is it a 30SD, a 30ELD, etc.
Old 09-06-2009, 07:45 AM
pistnbroke's Avatar
I try
electric start so may be an ELD .....let the owner speak........ so often these problems are solved and the original poster does not bother to say he sorted it and thanks ......
Old 09-11-2009, 12:13 AM
Rep: 13 Posts: 17
motor is 30eld. Control box has no markings at all, other than omc, heres a few pictures:
Thanks for all the helpful replies, except for par, you are a jacka$&. By no means is that supposed to be taken as an insult. This is the first outboard i've ever had to wire up, obviously, so keep the negativity to yourself please. Been very busy the past few weeks due to a horrible roommate situation, disappeared along with about 700 dollars worth of bill money. This is the first chance ive had to check this thread. Gonna take a look at yamahaoutboardparts.com but pist, how can i get ahold of your diagrams? That would be the smartest route i believe.
Old 09-11-2009, 01:27 AM
pistnbroke's Avatar
I try
well here we go
unfortunatly cannot get them direct from the disc to the screen ..if you were more local could post you a copy of the disc
The OMC diagrams are a pig to follow even direct from the disc ....good luck use the + 400 % bottom right on your tool bar to zoom in
Few Tips ....in the stop positon the key switch will be closed as it shorts out the igniton to stop the engine and in the run it will be open NOT LIKE A CAR .....in start you will have a connection from live feed to starter solenoid feed .
The ignition does not need a battery and is self contained ...you should have a stop switch on the motor ..wiring to this goes up to the key on the remote ....
If it has a rocker switch on the handle this is for the trim up /down and is a change over switch centre off ...threee wires .....
Wiring up yamaha 30-yamaha-001.jpg  Wiring up yamaha 30-yamaha-004.jpg  Wiring up yamaha 30-yamaha.jpg
Old 09-11-2009, 10:35 AM
There are two types of people in regard to these sort of things; those that don't like to do it, but certainly can and those that really shouldn't, because they don't understand why they shouldn't. You are one of the latter. No insult intended, but you just lack the expertise to track down the few simple circuits to get the basics of the engine operational . . .
Is there something about this that wasn't understood? Again, no insult intended, but you really don't have the skills to try this. This doesn't mean you can't, because you certainly can stumble through, possibly without burning up too many components in the process of "learning" how it works. Knowing you're not particularly "electrically inclined" isn't a personal flaw, the vast majority of folks are clueless in this regard.
People that have the skills for this type of work will do a few things, right from the start and they only involve are a mutli-meter and a pen and paper.
This is why I mentioned the brown wire. If you know what it does, just from the image, you're probably going to figure this out fairly quickly. If you don't know what that wire does, you're going to cuss a lot and again hopefully not BBQ and components as you learn.
Old 09-11-2009, 04:28 PM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
PAR,
Don't be so hard on the guy! If we all did only what we knew how to do, the human race would never have evolved.
I personally think that JDM is doing EXACTLY the right thing. He doesn't know how to get it running off the top of his head, so he's asking advice. If I was re-wiring an engine, I think I'd have to ask too (and I do interfacing electronics for fun!).
Good on you JDM,
Tim B.
Old 09-11-2009, 06:54 PM
I'm not trying to be hard on him, it's just that I've found certain types of work usually have certain types of people that do it, while everyone else just scratches their respective heads. Electrical systems is one of these fields. It's not disrespect, it's observation. Most people seeing a wire sticking out of something go to a bit of trouble to avoid touching it, because they may get "hit". Then there's the electrical guys, that will see the same wire, realize it's 12 VDC and nothing to worry about as they grab it and move it out of the way.
Yamaha HPDI 200hp wiring issues hmattos Outboards 0 04-17-2009 05:33 PM
New Yamaha Diesels Raggi_Thor Diesel Engines 0 10-23-2006 10:05 PM
Yamaha P45 iszzyinn Outboards 1 07-06-2006 09:10 AM
5 HP Yamaha Bodine Outboards 3 03-11-2006 12:30 AM
