Old 02-22-2008, 11:45 AM
BostonBoater BostonBoater is offline
Rep: 10 Posts: 2
Wiring Question
I am a new boater and have added a new stereo system to my 18 ft Bayliner.
I have 3 amps under the passenger cubby and 6 bose speakers in the boat
2 right in the bow which don't whine
2 mid boat which whine when I turn my boat on to Drive
2 of the stern which whine as well when I turn the boat on to drive
My question is I think I have a grounding problem in which the engine is emmitting enough energy to compromise the speaker wire and create the whine.
What if any suggestions might some of you have to correct this situation? Feedback would be appreciated. Thanks
Old 02-22-2008, 12:37 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1298 Posts: 1,991
Reckon you got a gasoline engine? With spark plugs it's allways a possibility to leaking radiowave inteference (or something named about like that ) Anyway if this the case the speakers closest the engine get the most of the disturbance, and it's easy to repair with a new set of plug wires and hats. In the worst case also the distributor cap.. Or you can chance to Diesel engine
If there's a grounding problem it should affect to all speakers... Ithink...
Old 02-22-2008, 06:23 PM
Rep: 2891 Posts: 8,798
You need to change your spark plug wires to "Spark Suppression" wires. Stop by the local parts store an get some good grade wires (almost all now are spark suppression). Toss in new plugs, rotor and cab while you're at it, as it's likely in need of a tune up anyway. You also could be picking up some RF from other sources. If this is the case, you'll probably want to have an audio person look over your system, it's a reasonably easy fix, most of the time.
Old 02-23-2008, 01:20 AM
Rep: 10 Posts: 2
thanks
I appreciate the info that sounds like it would work.
Fuel guage wiring question RalphPorter OnBoard Electronics & Controls 3 05-17-2007 07:50 PM
Wiring harness LP Electrical Systems 1 02-24-2007 12:38 PM
AQ170 Wiring CACowboy2203 Electrical Systems 3 08-09-2006 01:21 AM
Wiring Diagram scanvictoria Electrical Systems 2 06-12-2006 11:07 AM
Trailer wiring penguin82 Boat Design 10 06-04-2004 09:47 PM
