| Voltage drop I just bought a 1971 Cheoy Lee Clipper 36 in February. I have since instaled a DC refrigeration unit. Th refrigerator senses low voltage and reduces demand on the batteries. It also is not very effective when it does this. I have noticed a voltage drop of almost 1 volt from the battery to the back of the battery switch. This causes the refrigerator to slow down and sometimes stop. The original owner ( I bought it from the original owner) has added a lot of radio gear and other miscelainious wiring I am still trying to track down. I have been told that the battery cables could be old and maybe cracked. Is this a good place to start fixing the problem? |
| "I have noticed a voltage drop of almost 1 volt from the battery to the back of the battery switch" That is a very serious voltage frop mate, the batteru cables are obviously either too small or have a mechanical failure in them. I would expect on a 36 footer that the battery cables to the house battery would have to be capable of carrying up to 100 amps in operation. This would need a cable of #4 in your language, it will do about 150 amps over a 5 foot length (remember when measuring cables that the TOTAL length is the primary concern, that means from the battery to the unit and back again). Use a #2 wire if it is 10 feet. If you can tell me the wire length and the amperage of the whole house syatem, I can advise further.
| Voltage drop when running lights turned on | wheresbob | OnBoard Electronics & Controls | 7 | 06-06-2008 03:46 AM |
| Trickle charger, or Voltage robber? | thudpucker | Electrical Systems | 0 | 01-02-2008 04:17 PM |
| 12v Battery voltage regulation | alan_jeans | OnBoard Electronics & Controls | 4 | 08-07-2007 03:18 AM |
| The mysterious voltage transformer | m.s.j | Electrical Systems | 1 | 07-08-2007 02:14 PM |
| High voltage DC generator | prp25brad | Electrical Systems | 15 | 06-02-2006 09:55 AM |
