Old 07-04-2007, 02:37 PM
JimMayor007 JimMayor007 is offline
VHF Marine Radio Antenna Buying Guide
The best marine radio will not perform well when connected to the wrong antenna.
The type of antenna you should get depends on the distance you expect to transmit, available space on your boat, whether you need to lower your antenna for bridges or transporting your boat, and amount of "gain" your antenna should have.
The two major decisions you'll have to make are regarding the length of the antenna and its gain.
...read the full guide here
Old 07-04-2007, 08:42 PM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
VHF Marine Radio Antenna Info
The guide looks pretty good.
Bottom lines:
- Get the height. Typical foldover antenna mounts on a powerboat allow you to go as high as possible in open water. Just remember ! (I've smacked two in 20 years...)
- Use large diameter low-loss coaxial cable.
My Prejudice: ALWAYS have a smaller emergency antenna that can clamp on the rail, with a cable ready to plug into BOTH your main radio and your handheld radio. On a sailboat this can be a roll-up "J-Pole" that takes almost no storage space and can be hung from a shroud etc. in an emergency.
Another: Have all other regular crew members, including children, practice making a routine call, and setting the channel for emergency calls.
...It's a heck of a long way to shout if you have a problem.
Regards, Terry King ...On the Red Sea at KAUST
Old 07-16-2007, 04:49 PM
boatmarine boatmarine is offline
Rep: 10 Posts: 4
Good info, thanks
[URL="http://kresnamarine.com"]KresnaMarine[/URL] | [URL="http://boatmarine.info"]Boat Info[/URL] | [URL="http://fiberboats.blogspot.com"]fiberboats[/URL]
[URL="http://www.tkqlhce.com/click-2149720-8784130"][LEFT][LEFT][B]Best Boat Shop[/B]
[/URL]
mast mounted antenna externally mounted coax soundshooter OnBoard Electronics & Controls 3 03-26-2007 04:58 PM
Marine Radio Titanic Powerboats 7 09-28-2006 10:53 PM
Gel coat book or guide Smartbomb Fiberglass and Composite Boat Building 1 01-06-2006 02:08 PM
I need fastship user guide(manual) zzt9876 Software 1 01-26-2005 03:34 AM
Raymarin Vs Simrad VHF Radio zamibc Sailboats 1 12-25-2004 03:52 PM
