| Verify boat schematic I am wiring my boat and was hoping somebody will take a look and let me know if I have it close. The only thing I have currently is the outboard motor. Everything else is negotiable. Thanks. ![]() |
| A few things. Make sure when you wire the AC input to the HF1000 that you pick the correct terminals. They are marked but not that clearly. The outlets obviously go to the AC output. Bag the 30 amp fuse on the DC in and out of the batteries. That fuse is not typically used. Xantrex does not show that fuse to the best of my knowledge. I don't know what happens if you open the battery switch when making AC. Typically, inverters don't like that but it might be fine...check with Xantrex. I assume the DC panel has a connection to ground. Other than those very minor items you did great in my view. Ted |
| Superyacht Wiring Schematic | Landlubber | Electrical Systems | 11 | 10-25-2008 02:31 PM |
| a marine wiring schematic | ron phillips | Electrical Systems | 1 | 11-16-2005 04:31 PM |
| Battery Switching Schematic | 67-LS1 | Electrical Systems | 6 | 12-28-2004 09:52 AM |
| Electrical Schematic help | Craig_Hastie | Boat Design | 0 | 06-26-2004 07:30 PM |
| Trailer bearing schematic | Spearfisher_Man | Powerboats | 7 | 08-07-2003 04:13 PM |
