Old 08-23-2008, 03:03 PM
stuartyh stuartyh is offline
Rep: 10 Posts: 10
Unlock code for SEA222 SSB Radio
Hi guys My name is Jeff and I have a real problem.
I have this SEA 222 SSB when ever it is switched on and the usual test routine is finished it just goes into unlock and you cant enter anything or transmit.
Does anyone know the unlock code for this Radio or what is the method for unlocking it.
Any help will be appreciated.
Thaning u in advance.
Regards Jeff
Old 08-23-2008, 05:46 PM
lazeyjack
http://www.sea-dmi.com/marine/index.htm
WRITE OR CALL THESE people
Old 08-30-2008, 09:35 AM
Rep: 10 Posts: 10
Thank you for ur info
Ok Lazeyjack
thank u for the info but when I try to access their email site I cant seem to be getting through.
I am going to try again in a while and see what takes place.
So bye for now
Regards Jeff
Old 08-31-2008, 02:36 AM
Meanz Beanz Meanz Beanz is offline
Boom Doom Gloom Boom
Rep: 585 Posts: 2,286
Hmmmm my guess is that it will be unique and with the documents you got when you bought the radio.
Old 08-31-2008, 05:40 PM
Rep: 1729 Posts: 2,463
If you get really stuck I have the same radio in my yacht. I could copy the 2 eprom contents and email you the files if you can find an electronics hobbyist with an eprom burner ( try the HAM radio network contacts ).
Alternatively I could get them burnt here and post the chips, but my experience of mail in the Caribbean is that it can be unreliable for 'interesting' packages.
The eproms are socketed and easily changed.
Mike Johns.
Old 08-31-2008, 05:43 PM
the1much's Avatar
the1much the1much is offline
hippie dreams
Rep: 625 Posts: 3,931
if we can get it to work man,,, we can sell it,,,hehehehe
can ya believe someone just left this out here laying on the ground,,,heheehe
hehe ,,,,,Jim------>
Old 12-12-2008, 05:19 PM
fairbank56 fairbank56 is offline
Rep: 41 Posts: 22
It's not asking for an unlock code. It means the PLL (phase locked loop) circuit is unlocked. The radio needs servicing.
Eric
Old 12-12-2008, 06:03 PM
Thanks fairbanks, yes Jeff already worked that out .
Are you with SEA or a radio tech ?
Mike Johns.
Old 12-12-2008, 07:15 PM
Rep: 41 Posts: 22
I'm a marine electronics tech with a lot of experience with the 222. Repaired two of them today as a matter of fact. Good old radio's. Just found this forum while surfing around.
Eric
Old 12-12-2008, 07:48 PM
Do you know how to change the allowed frequencies ? I see them in the Eprom listing but the Australian model had some of them blocked but these channels are allowed overseas which is a pain. They should be convertable to the HAM bands as well.
Mike Johns.
Old 12-13-2008, 07:32 PM
Rep: 41 Posts: 22
Are you saying you can't program any freq you want into the scratchpad memory? I haven't seen one that was not completely "open". But it seems to me that I have some documentation somewhere at work about opening up the 222. I'll look into it this week.
Eric
Old 12-14-2008, 02:20 AM
Thanks for your reply
Scratchpad disabled in our models. I presume thats a bit of code in the EPROM.
If you have a hex or bin file of a US model eprom I'd like to give it a try.
cheers
Mike
Mike Johns.
Old 12-18-2008, 02:52 PM
File received
Thank you very much.
Mike Johns.
Old 02-04-2009, 10:04 AM
sidk sidk is offline
Rep: 10 Posts: 6
Key Pad etc
Eric
My Sea 222 keypad is bad. Flex cable melted. I connected a new key pad with correct wiring. Only some keys work..It appears the uprocessor has been damaged. I am not suprised with melted flex cable. I am suprised there was that much current availble. I can only locate the MC 146805E2P in quantities of hundreds. Can you tell me where I could buy one? I used to do radio repair but have been out of the business for years! Sid
Old 02-05-2009, 01:07 PM
Rep: 41 Posts: 22
Sounds like a moisture problem. Have you inspected the bottom of the circuit board in the area of J-3 and R169 thru 176? Checked for continuity/shorts of the pcb circuit traces from resistors to processor? Those resistors should have protected the microprocessor in the event of a short in the keypad ribbon connector. The keypad is a simple 4x4 matrix so you could rule out a bad keypad by just shorting the pins on the pcb...i.e. pin 4 to 5 is number 1, 4 to 6 is number 4...etc. I have no source for the processor but if the boat has a 1612 tuner, it has the same processor so you could swap it to verify that it is indeed the processor.
Eric
Viewer for ESSI-code Guest Software 3 01-31-2006 01:02 AM
Code Zero on a dinghy? usa2 Sailboats 2 12-14-2005 07:57 AM
Unsteady hydrodynamics code Tom_McGuinness Software 2 09-08-2003 02:29 PM
CFD code test matled Software 2 07-04-2003 03:51 AM
CFD Code giramonti Sailboats 2 10-13-2002 08:35 PM
