Old 01-09-2012, 05:10 PM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
The cables and control mechanism of the unoccupied station do indeed move and create friction, but on a 28 ft boat the total cable length is tiny. The cables to my flybridge are 30ft all by themselves, the salon station cables around 12ft for a total of 42ft per lever. It works fine, smooth and predictable.
With the use of the higher performance cables like the Teleflex Extreme or Morse Supreme dual station controls in parallel work very smoothly. Units in series are not as popular as units in parallel, and I have no direct experience with them.
The good things about this set up are, its conventional, parts are readily available, its redundant, and there is no changer, either station are ready and work whenever you grab a handle. There are also less costly than the Electronic Controls.
The Electronic controls are very nice, I have used the Yamaha ones and it is a very cool setup, very smooth easy feel. They may not be available from your motor's manufacturer for such a small motor and I believe they are rather pricey, even the aftermarket units.
Steve
Old 01-10-2012, 01:28 AM
MechaNik MechaNik is offline
Rep: 46 Posts: 92
For that size boat Mechanical is perfect. Go for a high quality cable to get the smoothest control on the long runs, but save some money on the short runs if you like.
I prefer series because I think it's important to know what is happening at both stations unless you could lock one out, it's also easier to assume control at the next station if you changed positions.
Old 01-10-2012, 04:11 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1188 Posts: 2,400
Luckily, I haven't bought the engine yet, so I can make a decision based on the ease and expense of dual controls when I buy.
I might have to take the installers advice on series or parallel.
I can see how having duplicated movement is handy if you want to do a quick switch from inside to out. Having some sort of switchover process could be a real nuisance in case of emergency.
Old 01-10-2012, 05:28 AM
Rep: 205 Posts: 442
Not sure I understand this comment. As far as the controls are concerned, they act identically regardless of in series or parallel. Unless you know which way they were rigged, you couldn't tell.
And with either rig there is no way to "lock out" a control
Steve
How do you compare electric motor power to diesel power? Yobarnacle Open Discussion: All Things Boats & Boating 114 12-30-2011 04:28 PM
help build boat power by motor sail and oars antoine51 Boat Design 0 12-12-2009 02:31 PM
Help! Need high power electric motor for small boats. SnappingTurtle Hybrid 9 08-13-2008 02:34 PM
perendev power/magnetic motor bradles1330 Propulsion 13 09-03-2006 04:14 PM
Trolling motor for aux power LP Sailboats 23 04-27-2006 11:10 AM
