| TV problem Like last year I took my TV to the boat but now only get sound, picture flashes and goes to grey. Thought it could be half charged battery’s but no, than paid € 45 to have the tube “repaired” but problem remained. Back home on 220 ac and in the car on 12 dc it works great..... Ok, this year the boat is a bit stuffed up between bigger ones and will check the shore power down but maybe one of you knows off hand what’s the problem? |
| TV problems Sorry can't help Yipster. Just worried that you should feel a need to take a TV aboard your boat.... ![]() |
| Ours has had to have the connection board, between where the cord comes in the back and all the internal gizmos, resoldered twice (6 years apart on a 13 year old tv) when the picture became warbly, but the sound was good. The guy said solder evaporates over time. I don't believe that, but he showed me what he did and it fixes the problem. |
| Its the antenna not the power supply. |
| fixed think it was me that did the rest of the shorepower cable in a twirl around the meter. i'm using a digital wireless pay receiver as analog channels are turned of the air years ago. will admit 5 minutes later the 12v fuse in the plug popped, my mistake again couse i used a shaver cord. can very well be the worn digi antenne cable still has knick but for now that tv shines as ever. now how to do economy wireless i-net ![]() |
| Yipster I only recently discovered that a TV tuner card in a laptop computer is a brilliant combination. Low power, you can record programs easily to the hard disk and so easy to move around. The tuner cards sell here for around $70 US. I was watching one yesterday you could even watch 4 channels at once (for the real TV addict).
| Mike Johns, Yipster said he has had the "tube repaired." Sounds like it's an ancient TV. These days you throw them away and buy a new one. And you want him to use a laptop?? I don't think he will be ready for that technology for around 10 years yet. If it works in your home and it works in your car there is nothing wrong with the TV. Assuming you have 12 volts in your boat and don't have voltage drop between the source power and your TV then we can rule that out. TV station signal. I don't know where you live but it might get a better reception at home than on your boat. Don't forget in a boat you are about sea level (I think). If you are using an antena cable make sure it has no sharp bends or kinks and avoid using cable clips it changes the impedence of the cable. Poida |
__________________ Trev F – Amateur designer and part-time layabout. |
| TV problems Or maybe if he took those glasses off the reception would improve... ![]() |
We bow down to you!! ![]()
| after walking the marina 3 times with a dumb tube i'll keep the sunglasses up |
| since its apperantly electronics day: wireless digital tv recievers signal is frequently changed by provider so need to be reset, i was dumb ![]() |
| Do I have a problem?? | hiracer | Metal Boat Building | 16 | 08-29-2006 08:05 PM |
| Problem - and solution? | caribmon | Boatbuilding | 4 | 07-24-2006 12:21 PM |
| problem | electricvoodoo | Boatbuilding | 7 | 09-09-2005 06:00 AM |
| Heating problem | CarbonKen | Propulsion | 8 | 08-20-2005 09:05 AM |
| A problem solved | DGreenwood | Electrical Systems | 0 | 11-28-2004 04:26 PM |
