#76
| AK- I'm not sure about radial-polarity, but I just remembered a way to prove the existence of mag. fields around a circ. (clockwise, or counter-clockwise) polarity magnet....early transformers. In early transformers, donut-shaped ferrous cores were wound with differing numbers of wraps of field-inducing (power source) or field-harvesting (altered output). The fact that these worked, and would unmistakeably HAVE to create a circular-polarized mag. field, proves to me that the field-effect of a circ.-polarized magnet extends outside of the magnetic material. That said, I'll stick with my circ-polar magnets for generating spin in a brushless motor, for now at least, or until experimentation proves me wrong. ![]() |
#77
| I have used thousands of ferrite "pot cores" in my radio and inverter power supply designs and the field is undetectable outside of the magnet; that is the reason for using them.
#78
| Like ancient kayaker pointed out, the field of a pot core cannot be detected: it is completely contained within the ferrite core. The same goes for ring core transformers and other wound-core designs. Only cheaply built transformers with welded together iron cores have part of their field outside. The direction and strength of the field follows the rules given by Faraday and Maxwell, no matter which core construction is used (even without one). |
#79
| CDK, I was hoping they would drop everything and actually build it. "Hmmm, I guess we had ought to actually study magnetics, then try again. Uh, oh, there´s a lot of laws and theorems and **** here..." |
#80
| well i am less than convinced it will work or i would likely make one so no wories it was just some fool thing i dreamed up years ago got my arm in a sling so forgive my worse than typically horrible typing skills B I was hoping at the time to create a way to take advantage of a rare earth magnets properties in kind of passive electrical generation and keep the thing magnetic by combining solar cells with the production technique to align the dipoles in the first place i wanted to store the electricity in the motion of the flywheel by slowly but consistently keeping pressure on the body forcing the armature to spin faster and faster through the field that, if it works would degrade the magnets so i tried to dream up a way to "charge" the magnets that's about the time I thought of using solar cells in some way hey Jim could a coil like whats on a old car be used to wind up the juice from a solar cell to charge a cap to then zap the magnet to help keep it "charged" |
#81
There is a simple way to make a magnetic construction rotate or move. You must use ferrite magnets with a low Curie point. By selective heating one magnet and shielding the other, you have a simple albeit slow hot air engine that could recover energy from exhaust gases. |
#82
| But you are talking about an active system with outside influence (made me think, how´s BMW capturing exhaust heat for added power?). I did some work with induced fields and quasi-stability in levitation (it has to be moving. Talking induced field mag-lev) on an invention of MINE and gave up until I was more prepared. I´m still not there, but have first-hand experience in being defeated by Earnshaw´s theorem and more and more appreciation of how difficult it is to go from "that should happen" to working mechanism and the doers who actually get somewhere...Also, those interested in magnetics take my word that NIB and SmCo will pinch flesh OFF and SmCo will easily shatter and threaten to blind. This stuff is not for the timid. Halbach arrays are cool and worth studying to excersize the mind and appreciate smart people, too. |
| Mirabaud-Super Foiler! | Doug Lord | Sailboats | 30 | 10-12-2010 06:53 AM |
| simms super v jet drive | traveliner | Jet Drives | 1 | 03-26-2010 08:54 PM |
| Lets talk some Super 14.... | Wynand N | Open Discussion: All Things Boats & Boating | 5 | 05-08-2007 07:42 AM |
| Super Panga | regal | Boat Design | 11 | 10-30-2006 11:31 PM |
| Super PUGS... | Sean Herron | Boat Design | 1 | 05-23-2005 02:33 PM |
