Old 01-05-2012, 02:19 PM
jollyricard jollyricard is offline
Rep: 10 Posts: 73
stand by
dear all,
What is a stand by of a pump?
is the automatic start? or is the stop of the pump in case of small flow?
Old 01-05-2012, 03:47 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
....sorry mate, hard to really understand in those few words exactly what you want, but a standy pump is a pump that is NOT in regular use, it is to be used as either an extra pump or in emergency...it is plumbed in and ready ti use, but not in regular use....hope this helps.
Old 01-05-2012, 06:23 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
If you rewrite exactly how you read it (eg. off a pump spec.) it would be easier to understand and reply.
Old 01-06-2012, 02:02 AM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1020 Posts: 585
Stand by could mean the pump is activated by a float switch, as long as there is no water the pump is on stand by . . . .
Cheers,
Angel
Old 01-06-2012, 06:10 AM
Rep: 1493 Posts: 7,447
Stand by means "ready to use or deploy". With equipment it is often a backup system.
Old 01-06-2012, 11:45 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
I'll look it up, stand-by...
-Tom
Old 01-07-2012, 04:20 PM
Rep: 10 Posts: 73
ok. three pumps was installed on board a boat, chief engineer told me to verify the stand- by pump; but i dont understand in what consist the "stand by pump ". What must I to do for verify it?
Old 01-07-2012, 04:40 PM
Landlubber's Avatar
...again mate, your translation is not getting thru to us, can you quote directly what it says and we can then try to explain it in a different manner that may help you, ta, JOhn
Old 01-07-2012, 06:52 PM
Landlubber, I feel that if he quotes exactly what it says, it will be in Italian.
Maybe if it is written in Italian, someone in the forum who can better translate, can advise what the actual question is.
Poida
Old 01-08-2012, 02:20 PM
Rep: 10 Posts: 73
ok. three pumps was installed on board a boat, chief engineer told me to verify the stand- by pump; but i dont understand in what consist the "stand by pump " what must I to do for verify it?
Old 01-08-2012, 02:26 PM
Mariner
I suspect he/she wanted you to test the stand-by pump and see if it was serviceable.
It may have been prudent to also check if it would automatically engage (start) when commanded to do so (again, automatically).
Perhaps you should ask the Chief for clarification.
-Tom
Old 01-08-2012, 03:49 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
A stand-by pump starts automatically when needed, perhaps to take over from a failed pump or to pump out bilge-water when it gets above a certain level. When not required it is "standing by" - still connected to electrical power but not running. A common type of stand-by pump has a battery power supply and runs only if the main (duty) pump fails or loses power. The stand-by pump in a sewage system will run if the main pump becomes overloaded during a storm, or if the main pump is being serviced.
To test a bilge-water pump you would raise the float and ensure the pump turns on, and off again when you lower it.
A pump that is NOT a stand-by pump may be a cooling pump, or a pump for the head (wash basin or flush toilet), or even a fuel pump. So you need to eliminate the 2 pumps that can be started with a manual control; once you have located all 3 pumps it should be obvious which one is a stand-by.
Dances with Turkeys
Old 01-09-2012, 09:31 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1874 Posts: 3,357
I think he means to activate it by lifting the float lever to make sure it is functional.
Hoyt
Old 01-09-2012, 09:33 AM
hoytedow's Avatar
Resistor
jollyricard, you have 3 pumps. Describe them.
Hoyt
Old 01-23-2012, 03:50 PM
Rep: 10 Posts: 73
ok, i have following pumps :
fuel pump, bilge pump and ballast pump!!!!!
Stand-up Paddleboard Design Doug Lord Boat Design 14 11-10-2011 07:48 AM
the great race ( a chance to let those able few stand up ) Boston Boat Design 17 11-30-2008 10:00 PM
stand up walk around stability in a rowing boat thudpucker Stability 11 10-19-2008 06:31 PM
Removable Mast stand on a deck or beam Fanie Open Discussion: All Things Boats & Boating 18 08-02-2008 11:52 AM
deer stand molds bobbyfrench Boat Molds 3 05-20-2006 12:50 PM
