Old 07-02-2007, 06:40 AM
seanform seanform is offline
Rep: 10 Posts: 10
Solar panel to charge battery
Hello everyone. On my boat I have two batteries,one 100AH and one 125 AH. I would like to keep them (or at least one) constantly on charge with a solar panel. How much current does the solar panel need to be? 10x
Old 07-03-2007, 05:26 AM
Verytricky Verytricky is offline
Large Member
Rep: 395 Posts: 248
Approximately 3w per 100AH unregulated.
This is to 'hold' a charge, and not to charge a battery.
Youy need to ensure that your battery can not 'charge' your solar pannel at night, as the losses there would negate putting on a pannel - so use a diode to restrict flow direction. If you exceed around 6w per 100ah you need to look at a regulator that turns off the charge when the battery is full. This assumes a battery in good working order. An old or damaged battery would probably require a higher charge, but dammage will occur if you consistantly overcharge a battery.
If you are using wind generation you need definately a regulator and a 'dump' to prevent damage to the electrics.
batt charge question dupsta OnBoard Electronics & Controls 4 05-24-2007 01:32 AM
charge 4 batt with three outputs? dupsta OnBoard Electronics & Controls 1 04-09-2007 06:20 AM
Solara AG Solar Panel Warranty Woes geoffschultz Electrical Systems 12 03-07-2007 03:50 AM
Accessories/Battery help thebassn8tr Boat Design 7 01-15-2007 09:55 PM
what means charge loop motor riveramunizaga Outboards 8 09-14-2005 07:15 PM
