Old 05-09-2009, 01:55 PM
CDK's Avatar
CDK CDK is online now
experimental engineer
Rep: 1316 Posts: 2,148
Simpson-Lawrence anchor winch
Albeit long ago, at one point in my life I decided to invest a lot of money in an electric anchor winch. Not an Asian product named Yong fang or Ying Chan, but a serious UK made product from Simpson-Lawrence.
Above deck everything is stainless steel and chrome plated brass, all parts below deck were painted.
Yesterday, when preparing the boat for the summer season, it turned out that the winch didn't work. Pressing the up or down button resulted in a current surge well over 100 Amps.
So I dismantled the winch as far as possible. The painted below deck parts looked like unidentifiable objects from a junkyard. When I removed the bottom of the gearbox, a copious amount of water and a bit of oil came out, the badly rusted electric motor produced water without oil.
Complete dismantling of the winch is impossible because the stainless steel shaft is stuck in a collar made from cheap, rusty iron. I also found some shims that were dangling from a shaft because at the time of assembly many years ago, someone put them at the wrong side of the bearing.
If the manufacturer had pushed a 0.05 $ plastic washer on the vertical shaft, no water wound have dropped on the seal that should keep the water out and the oil in.
I have removed all the debris, cleaned and polished the bearing surfaces as good as was possible, reassembled everything and installed the winch. Because of the damaged bearings I left out some rings so everything has some play, but at least it is serviceable again until I buy a new winch.
It now makes exactly the same rattling noise I hear throughout the summer when sailing boats anchor in our bay.....
Old 05-09-2009, 02:28 PM
apex1
Reminds me of the 70ies and 80ies when British cars were named "British Elend" in Germany, according to British Leyland, and meaning British poverty.
"Lofrans" and "Maxwell" are usually my choice and "Steen" if well above 30 meter. Not a bargain buy but worth the price.
Regards
Richard
Parachute Anchors, Para-Anchor, Sea Anchor brian eiland Boat Design 28 05-06-2009 03:11 AM
anchor and anchor winch questions martinf Boat Design 7 04-05-2008 07:10 PM
Simpson Lawrence Seahorse windlass jimisbell Open Discussion: All Things Boats & Boating 2 10-02-2006 06:29 PM
Choosing a anchor and winch jmac Metal Boat Building 12 05-04-2006 07:16 AM
anchor winch motor Peter Baker Electrical Systems 2 07-13-2005 10:32 AM
