Old 06-08-2009, 02:05 PM
CDK's Avatar
CDK CDK is online now
experimental engineer
Rep: 1316 Posts: 2,146
Simple wiring diagram for small craft
Regularly I've seen questions on this forum about electrical wiring because that is still a mystery for many boat owners.
Here is a simple wiring diagram for motor- and sailing boats with one engine and just the basic equipment. There are only 7 wires shown that connect the engine bay; I omitted temp. gauges, rev counters etc. which all have their own wires or cables. The ignition wire is not used for diesels, but there it can be used for the fuel valve.
A friendly reader in the US is invited to translate my wire sizes from mm2 to AWG numbers. Parts like the diode bridge and 4-way battery switch are available from Vetus in Europe, I did not look for US suppliers.
Drawings are shown as .JPG, but also available as .CDR (Corel draw).
Boat owners who have no idea what this all means should of course hire a qualified technician!
Simple wiring diagram for small craft-electrical1.jpg  Simple wiring diagram for small craft-electrical2.jpg
Old 06-08-2009, 06:26 PM
apex1
COMPACT
DUTCH
KNOWLEDGE
as usual......................
Old 06-09-2009, 04:10 AM
Knut Sand's Avatar
Knut Sand Knut Sand is offline
Rep: 451 Posts: 509
Pretty.
I once, somewhere suggested automatic 12 vdc diode light in the engine compartment, biwired together with the bilge pump. Also on the same biwire an alarm/ buzzer located at the steering position (with on/ off switch, normally set at "on") telling the driver that something is going on down under..... In case, it can cive you a few extra minutes.... For a low cost....
KnutS
"it's dark and we're wearing sunglasses"
Old 06-09-2009, 09:19 AM
BillyDoc BillyDoc is offline
Rep: 266 Posts: 421
Nice, Knut, very useful!
BillyDoc
Old 06-13-2009, 11:22 AM
Delane's Avatar
Delane Delane is offline
Rep: 33 Posts: 72
Small Boat Wiring Pictures
Re-wired my J-24. Basically pulled everything and started over. The goal was simplicity in design and to not use one of those typical switch panels. I used a 100 volt A/C switches. Have any questions, please ask.
Simple wiring diagram for small craft-electrical-panel.jpg  Simple wiring diagram for small craft-power-panel-1.jpg  Simple wiring diagram for small craft-power-bilge-controller.jpg
Old 06-13-2009, 12:19 PM
BeauVrolyk's Avatar
BeauVrolyk BeauVrolyk is offline
Sailor
Rep: 153 Posts: 160
I am looking at a rewire on my boat as well, similar size and complexity. I was wondering why you didn't use one of the plastic boxes with the clear lid to contain all the junctions? I get a fair amount of water aboard, probably a lot like a J24 when races, and the last junction strip just turned into a ball of salty corrosion.
Beau
"Anything worth doing is worth doing to excess"
Old 06-13-2009, 01:07 PM
Delane's Avatar
Rep: 33 Posts: 72
Dry Boat
My wiring is inside of a closed compartment and the boat is very dry. Tabernacle mast set up and everything has been re-beaded. Bone dry and I have a solar vent to circulate air.
Old 06-13-2009, 02:09 PM
BeauVrolyk's Avatar
Sailor
Rep: 153 Posts: 160
You're lucky. The water in my boat doesn't leak in, it's carried in by the soaking wet spinnaker and headsails during sail changes in heavy seas. That and the sopping foul weather gear etc... We typically sail in 20 to 30 knots of breeze and big waves - it's wet. It must be nice to have a dry boat, none of the J24s around here are dry if they're raced.
B
Old 06-13-2009, 02:12 PM
BeauVrolyk's Avatar
Sailor
Rep: 153 Posts: 160
I am curious why you've used both circuit breakers and fuses. Is there a specific reason? I have had great luck with waterproof circuit breakers and pretty bad luck with the contacts on fuses.
Beau
Old 06-13-2009, 08:51 PM
Delane's Avatar
Rep: 33 Posts: 72
Only Switches & Fuses
The switches are not the breaker type. That little fuse box was the most expensive part of the whole panel at $40 by the time it arrived.
Old 06-14-2009, 06:00 AM
CDK's Avatar
Beau
No, I used switches and fuses, but of course you could also take automatic circuit breakers if you don't mind the extra cost.
Because this post was only meant to help people getting started, I did not supply detailed info. Perhaps I should have.
Fuses are absolutely necessary to protect your safety, but with proper, careful wiring they should never do what they are designed for: blow. So the should cost as little as possible. The automotive type with knife contacts costs only a few cents and makes reliable contact with a socket or crimp terminal. Glass fuses in a fuse holder are very unreliable in a marine environment but you already found that out. Some grease or Vaseline prevents corrosion of fuse contacts but is seldom used.
Old 01-06-2010, 02:18 AM
zamgod zamgod is offline
Rep: 10 Posts: 13
CDK, can I ask what the box at the bottom left of your drawing is?
The one where most of the wires feed into.
Thanks.
Old 01-06-2010, 04:36 AM
CDK's Avatar
That box is the engine compartment.
There are only 7 wires connecting it to the rest of electrical parts that is located elsewhere on board, i.e. under the steering console or in the cabin.
Old 01-06-2010, 12:22 PM
Rep: 418 Posts: 777
Very nice basic set up to get people started.
I've wondered about taking common cheap ac switches like Delane used and attaching pigtails potting them with epoxy.
Old 01-06-2010, 01:38 PM
Rep: 1397 Posts: 7,216
If you have fuel onboard, those switches are not spark protected. That means the possibility of fire or explosion.
Typical wiring schematic/diagram MCDUNK Electrical Systems 14 08-15-2010 12:11 PM
Wiring diagram for an O/B. LP Electrical Systems 14 05-02-2009 08:27 PM
wiring diagram for `46 catamaran guest200901 Multihulls 9 09-27-2007 11:03 AM
Standerd wiring diagram sharkfish OnBoard Electronics & Controls 2 05-23-2007 02:31 AM
Wiring Diagram scanvictoria Electrical Systems 2 06-12-2006 11:07 AM
