BillyDoc
- Joined
- May 24, 2005
- Posts
- 420
- Reaction score
- 18
- Location
- Pensacola, Florida
I spent some time today trying to find circuits for implementing simple Maximum Power Point Tracking charge controllers. The commercial ones I have seen are all overpriced, in my opinion, or way too capable for my needs. So, I thought I would try to design one. At this time I only want to keep a single marine battery charged with what I think is about a 20 watt solar panel. It's for a cabin I have deep in the woods.
So far I have found two interesting circuits from the same man, W. Stephen Woodward (pdfs attached). The first (MPPT battery charger) describes pretty much what I am looking for, but uses a buck-only Switch Mode Power Controller (SMPC), thus limiting charging to those conditions where the voltage output from the solar panel exceeds the battery voltage by some amount. It also has a feature for dropping the charge current back to "trickle" when the battery voltage reaches fully charged, which I think is a necessity.
The second circuit (Solar array controller) is more sophisticated and uses a boost-buck SMPC, however the one chosen is a surface-mount device with 141 tiny pins!!! It's also damn expensive ($45). I really, really don't want to solder that thing up. The circuit as a whole also seems to lack a "fully charged" mode.
With a lot of study I think I can extract the best features of the two designs, but as I've mentioned before on this forum I'm lazy on principle and would love to get some help here. The MPPT approach seems to me to be the only way to go for this problem. So, has anyone else found good circuit ideas that implement MPPT for small systems? Or, have any good ideas of your own?
BillyDoc
BillyDoc
