Old 12-20-2007, 08:40 PM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1528 Posts: 5,519
Shaft anode information
I think it would be very interesting to see how often people change shaft anodes.
Please donate your shaft information as below example.
2X 24 inch bronze 4 blade props. 4 foot 2.5 inch st/st shafts
Batteries mostly on/off= off
Anode life 10 months
Hull type = Fibre glass
Old 12-20-2007, 10:23 PM
Kay9 Kay9 is offline
1600T Master
Rep: 279 Posts: 615
I have 2 boats I own and 2 I maintain.
My first boat is 35' wood hulls 4 blade prop 21/4 shaft 5lb Annode every 2 years with 20%+ left.
2nd Boat is a 26' Alum hull 3 blade prop 1" shaft. 2Lb shaft annode and 20lb hull annodes....change every 2 years with 20%+ left.
Boat 3 and 4 are both steel with 3 blade props I have over 40 lbs of hull annodes on them, no a ctuall shaft or prop annode. Again I change them every 2 years with about 20% left.
I also use a throw in 20 lb annode that I attach via 6 ga wire to the engine block when the boats will be tied up for a long period of time.
is it a short shaft or long shaft? donell67 Outboards 2 03-14-2007 12:07 AM
long shaft or short shaft Bill Kubiak Powerboats 17 05-26-2006 01:00 PM
Shaft SF's caseytcampbell Boat Design 2 04-28-2005 12:53 PM
short shaft motor on long shaft boat ohenry Boat Design 0 03-21-2005 09:02 PM
Will I need a zinc anode? Matthew Boat Design 3 08-25-2004 08:56 AM
