Old 09-10-2010, 12:07 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
Sorry to say I dont agree with manual switches ..you just forget to operate them and its all a waste of time...what you need is a VSR ..voltage sensitive relay .....when battery volts reaches 13.6 it connects in the extra battery and disconnects it when main battery volts falls...I dont know how reliable the post in in Eygpt ..bad I suppose but lots on e bay ..used for caravans and 4x4 of which (4x4) that is you have a lot in egypt...
Old 09-10-2010, 03:43 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
So if enough drivers forget to release the handbrake we reward stupidity by installing automatic ones? Citroen has done just that: if the battery is dead there is no way to move the car!
I once made a motorized switch for a guy who wanted state of art circuitry in his sailing yacht. A VDR isn't enough, when starting you want both batteries connected and during starting there should be no switching so as not to fuse the relay contacts.
The solution I came up with used a microprocessor and the stepper motor from a 5.25" floppy drive to move a solid copper wedge between two contact springs that could carry 300 Amps. Because the micro was over-qualified for the job I added a display to inform the owner about the battery status.
In my own boat I use a 4-way Vetus switch and never forgot to operate it in the past 25 years.
Old 09-10-2010, 06:20 AM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
I am a bit old school. I still have my old wave runner jet ski 2 stroke engines and although its an old model, its simplicity and ease of repair for me outweighs and new overpowered computer / electrical controlled models.
So yah switch sounds like the choice i would take, specially the boat is a 5.5 meter cuddy cabin.
The Mummies Dummy guide to boat building stuff!!!
"All of us could take a lesson from the weather. It pays no attention to criticism."
"Learn wisdom when you can its gona help you out some day in your life"
Old 09-10-2010, 04:10 PM
pistnbroke's Avatar
I try
usually you have one battery for starting and one for the accessories joined by a VSR ...then if your start battery fails you switch in the other battery with a big two pole switch and off you go hopefully....everyone to his own
Old 09-10-2010, 04:33 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
i dont know what you mean by a VSR
Old 09-10-2010, 04:35 PM
Bglad Bglad is offline
Rep: 67 Posts: 156
I like the VSR for a small boat. If you are out messing about stopping and going you will end up turning the switch a lot so you don't kill your cranking battery running house loads such as refrigerator and nice stereo system. If you just want to have a battery ready to go when you get aboard or don't have significant house loads then the manual switch is fine.
Old 09-10-2010, 06:08 PM
pistnbroke's Avatar
I try
think I already explained it ...Voltage Sensitive Relay ...used in caravans boats and 4x4.....joins the batteries when the starter battery gets to 13.6 and disconnects when it goes lower...three wires ..earth . bat 1 pos and bat 2 pos....photo of one attached but its an expensive marine version ..check at your caravan RV shop ...you dont need 125 A as the max charge current you will get to your second battery is about 25 A
Old 09-10-2010, 06:11 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
Sorry to say I dont agree with manual switches ..you just forget to operate them and its all a waste of time...what you need is a VDR ..voltage dependent relay
Then you said VSR, thought it was a different thing just a typo then
Old 09-11-2010, 09:05 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Yep they do just as they say on the packet
and they are fool proof
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
  #25
Old 09-11-2010, 03:38 PM
Rep: 67 Posts: 156
Told an operator I was training on a piece of equipment that it was "fool proof". She then looked me right in the eye and told me she wasn't a fool she was an idiot. Turns out the equipment was pretty much "idiot proof" too
Dual helm stations, dual control heads for dual engines Scrumble Diesel Engines 2 02-02-2010 08:19 AM
Quick Question Mykul Multihulls 3 09-18-2008 05:51 PM
Quick question for those who,..been there done that! Roly Fiberglass and Composite Boat Building 3 12-25-2006 07:50 PM
quick question about bondo inthegarage Fiberglass and Composite Boat Building 41 10-01-2006 09:05 PM
quick/simple question millrtim247 Materials 4 07-07-2006 12:13 PM
