Old 08-19-2009, 10:28 PM
sportfisher sportfisher is offline
Rep: 10 Posts: 7
Is it possible to shield the compass for an auto-pilot?
I recently purchased a used 2004 27' Center Console. The boat came with a Ray Marine ST6001 auto-pilot. I calibrated the compass according to the units owner’s manual. I cannot get the auto pilots compass deviation better than 30 deg. The compass for the auto pilot is located in the inside of the console and against the most forward wall. It is about 4' - 5' from any electronics and about 3' to 4' from the batteries. It is right next to the electric head.
I'm assuming there is something interfering with the compass and not something wrong with it.
Is there any way I can shield the compass from ferrous metals. If shielding is not an option, does anyone have a suggestion for a new location?
Old 08-20-2009, 08:17 AM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
You need to find what is causing the extra magnetic field near your autopilot.
Start with a handheld compass, such as for hiking. Hold it as far above the location as possible to determine the unaffected indication. Now start right at the autopilot location. How much is it deflected? Start moving it around and quite close to metal objects to find out what might be affecting the autopilot.
I'd bet that you'll get a big deflection near the motor on the head...
Current-carrying wires will also have a field. Totally disconnect the battery, and then check the same location with the battery connected.
I've heard stories of autopilots that steered differently as electric winches were operated.
Shielding: You obviously don't want to shield the autopilot which is looking for the earth's magnetic field! Shielding the SOURCE of a magnetic field is possible. Steel sheet of perhaps .050 inches is a start. Multiple layers with insulating material in between are sometimes used. More complex multilayer shielding (google "mu metal" ) is possible but not cheap.
I'd use the hand compass to find a good relocation prospect. Check any location again with the boat yawed 90 degrees: you MIGHT have been on a bearing where effects cancelled out..
And let us know what you find...
Regards, Terry King ...On the Red Sea at KAUST
Old 08-20-2009, 11:07 AM
Luckless Luckless is offline
Rep: 105 Posts: 162
My first thought is, can you get somewhere fairly clear of power lines, running engines, and large amounts of iron? (like a field) that you can work out detailed bearings from a map, and be sure the unit is functioning properly away from the boat.
No sense chasing EM emissions around your boat if the unit is half dead already.
Old 08-20-2009, 11:56 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1943 Posts: 4,195
If it is magnetism causing the problem then you can shield it off.
http://www.lessemf.com/mag-shld.html
You will typically need the MagnetShield product, they have a description there somewhere on how to shield magnets. It sounds like it is the electric head you will want to shield.
Couldn't find a shop closer to home
Regards
Fanie
Water ! Just gimme water !
Old 08-20-2009, 06:20 PM
Rep: 10 Posts: 7
Thank you for the reply. I'm going to take a hand held compass and compare a few different readings. I'll let you know what I come up with.
Robertson auto pilot complete AP45 system Kobelt 7050 and oil tank for hydraulic stee Toolman Marketplace 12 08-03-2009 07:46 PM
Anyone with robertson AP2500 Auto Pilot.... stuartyh OnBoard Electronics & Controls 1 09-23-2008 11:41 AM
auto pilot pumps lazeyjack Boat Design 3 04-20-2008 06:01 AM
Auto Control Pilot - CETREK england darlian Marketplace 0 03-23-2008 10:26 PM
Auto pilot systems Fanie Boat Design 4 10-31-2007 06:50 AM
