Old 12-05-2008, 12:34 PM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
If you succeed in overcharging your battery with the panel you've described, you can probably walk on water too.
I have a 16 Wp panel and 240 Ah of batteries, live in the sunniest part of Europe, yet the charge is only just sufficient to compensate for self-discharge, the bilge pump and 8 mA for the alarm system.
In the past, I had a bilge pump with only a float switch: the panel could not cope with the power consumption. Pump and switch kept each other busy for hours because the back-flow of the water still in the hose was enough to switch the pump back on again.
So I added an rc-delay and a transistor that keeps the pump going for approx. 10 seconds after the float breaks the circuit.
Old 12-05-2008, 10:34 PM
Ratch Ratch is offline
Rep: 10 Posts: 26
Hi CDK
We started discussing overcharging the battery when Stuft decided to get a new panel.
As things stand now:
Battery size - unknown
Panel size - unknown (was an old 5w)
Pump size - 1.9amp@12v (googled make)
Pump run time - guessing between 5-10min per day.
Mooring location - Sydney or around there
Old 12-06-2008, 02:03 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Thanks Ratch, I missed that. My 1200 m. telephone cable, hanging on poles under the power cable makes the internet very slow sometimes.
Stuft mentioned 350 Amps for the battery: I guess he meant cranking current, so the capacity will be approx. 50 Ah.
control panel for lights and 12v plug in quit working jd87 Electrical Systems 0 08-04-2008 12:58 PM
new (old) option! Starfish Wooden Boat Building and Restoration 13 03-17-2008 09:15 PM
$1/watt solar panel - $2/watt solar system jorghenderson OnBoard Electronics & Controls 24 02-10-2008 06:24 AM
Solar panel to charge battery seanform OnBoard Electronics & Controls 1 07-03-2007 04:26 AM
Solara AG Solar Panel Warranty Woes geoffschultz Electrical Systems 12 03-07-2007 02:50 AM
