Old 04-03-2007, 06:26 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 604
Originally Posted by marshmat View Post
If your helm looks like the pilot's station of the Starship Enterprise, so much the better.
Absolutely.
Nice thread hijack guys!
Old 04-03-2007, 09:17 PM
Delta Delta is offline
Rep: 10 Posts: 18
New Guy comment
Oh, boy, do I have my work cut out for me. I am about to embark on completely rewiring my 1977 Whitby 42 sailboat (Hey, it's Canadian built, that's good here, right?) and have torn out the old panel and he boat is on the blocks and all I have to do is.....figure out what I need to do. Googled here and saw these totally excellent wiring schemes and am now depressed! Man, you guys are good. I'm still looking for a good book or two to get me started and you guys are turning out works of art! I had a 50 Amp AC shore power I want to duplicate and had an Onan Genset 7.5KW that I tore out and will eventually replace. My engine room is bare (Main engine out as well) so I can start anew. I guess I'll simply start reading through all these forums to glean what knowledge I can get. I do know I want a clean install like you guys have and want all new wiring. I may get an inverter as well so I'll plan on that in the grand plan. Thanks for a good start. Ummm....any good book recommendations on how to go about this? Thanks, folks,
Delta
Old 04-03-2007, 09:28 PM
Rep: 578 Posts: 604
Welcome Delta
Two come to mind.
Boatowner's Mechanical and Electrical Manual by Nigel Calder
Boatowner's Illustrated Electrical Handbook by Charlie Wing
There are plenty of others. A quick Google search on marine wiring or marine electrical will give you plenty of research but I do recommend the two I've listed above. If you want to start a separate thread we can work together and I'll sketch out your plan like I did for my project. Kind of like an "electrical plan by committee" *lol*.
Rick
Old 04-04-2007, 12:43 AM
Rep: 10 Posts: 18
Thanks Rick!!
Appreciate the hospitality........and advice for books. This is one project that I think I have the "long term" patience to do right.
Old 04-04-2007, 06:30 AM
Rep: 578 Posts: 604
Peter Eikenberry mentions a few more on this thread....
rewireing outboard 1993 cobra bass boat
You might want to check out his web site. Plenty of info there to get you started. Good luck on your project.
Old 04-04-2007, 08:39 AM
Rep: 578 Posts: 604
New from Bluesea
A new line of modular panels from Bluesea including of all things a "mimic panel"! ;o) And I was just about to patent my idea!
http://bluesea.com/viewresource/476
I like the idea of the modular design as it adds a lot of flexibility for upgrades down the line. I can see it driving up the complexity of the basic system design quite a bit though. Those familiar with Bluesea systems would probably adapt pretty quick.
There's a lot of good info on the Bluesea site Delta. Worthy of a look. You can get a copy of their catalogue which is chock-a-block with info.
Old 04-04-2007, 12:46 PM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Especially if it's on an original-looking (exterior) old Chinese fishing boat or Junk,
(which is distinctly possible!)
Regards, Terry King ...On the Red Sea at KAUST
Old 04-06-2007, 08:26 PM
Rep: 10 Posts: 18
Ummm, Blue Sea systems.....may be the easy way out for a novice like me. Great site here. Gonna order the catalog. Thanks, man.
Oooh. I see they sell through Lewis Marine - we have an account there!!! Right on.
Old 04-06-2007, 09:00 PM
Rep: 10 Posts: 18
Nice, KBz
On my boat I have two AC units, water heater, air/water cooled refrigeration, trash compacter, batter charger, bunch of lighting on the 110 side. Of course, gonna upgrade a lot of that.
Who knows what I'll add on the DC side but I want to have capacity.
Inverter? Why Knot? (Partial Pun intended)
7 or 8 KW generator to go in to give me fifty amps.
50 amp shore power.
Oh, man, this is gonna be surreal.
From this point in time it all seems a little overwhelming but the sky's the limit and I have the time. (Although the marina charges are killing me even though I am on the blocks)
I'll be lurking here, for sure. Once I get an idea of where I'm headed, I'll start adding up all the amps I'll need!!!!
Thanks, folks.
  #25
Old 04-06-2007, 10:06 PM
Rep: 578 Posts: 604
You might want to try e-Bay for a slightly used nuclear reactor!!!
Looking forward to following your progress. Take lots of pics and post them please. Good luck!
Rick
  #26
Old 04-07-2007, 01:15 PM
Rep: 10 Posts: 18
Affirmative
Yeah, first things first. I'm still dismantling the interior and finally - after fifteen years - glassing over some leaks that were behind the engine panel area. Seems like the gap between the deck liner and the interior liner had a gap where water from the cockpit was getting through. Gonna paint the interior and get better access to the wire runs. One problem I face is time. I have been living one month here in Fl working and one month off in the CO mountains on my time off for the past decade so my work on the boat has been limited to ensuring she is kept dry and mildew free. When I'm here I run fans all the time and when I'm off I have had one of my employees going down and running fans two times a week. Gonna have to start spending more time here in FL on my time off which means in the summer months I need to hook up a portable AC unit as it is too freakin hot here to even work!!! Also gonna replace all ten portlights with stainless ones - still looking at where for that - so this will indeed be a work in progress. I will post a picture of the area where I tore out the original electrical - pretty stark - and hopefully see how we progress from there. Thanks.
Glen-L Squirt Project Photos Rudderman Wooden Boat Building and Restoration 8 06-14-2005 08:05 PM
54' sailboat construction photos paulkr Sailboats 0 06-10-2005 09:20 AM
Drawings and photos of CLARA and MINERVA ThomasAndersson Wooden Boat Building and Restoration 2 01-20-2005 12:40 AM
Kookaburra keel photos Fco.Lopez Sailboats 2 03-31-2004 07:51 AM
Photos of Mini Transat under construction Zaynab Boatbuilding 0 11-03-2003 06:07 AM
