#31
| The forward conduction voltage of an SCR at rated current is about 1.8V. For this reason I would not recommend it for the application being discussed. |
#32
| As i have no idea whats inside an ALT's, can some one please send me a schmatic of a typical alt system. |
#33
| MATTS ...I think you lost the plot those are a tripple diode pack not SCR ...the only scr used was in the locked on VSR DAVE J its called Google |
#34
A pretty good if basic description of their function in a vehicle context can be found here. On the subject of SCRs, I've never seen one used in a charging application. The most common component used for parallelling batteries is a Duralit relay if you want cheap, or an Albright contactor if you want good and reliable. Regards, Tony |
#35
| that is the worst altenator diagram I have ever seen ...Its three phase for gods sake .. Duralite relay ...take the top off ..examine then put it in the bin .... |
#36
#37
| yes a 10 diode alternator and rotor current ECU controlled ..... |
#38
#39
#40
| Has anybody considered a boost converter for getting a full charge on the house batteries from the starting battery and charging system? It's kind of a DC transformer. http://en.wikipedia.org/wiki/Boost_converter |
#41
| The RE55 which you can use on either of the two practical circuits allows you to boost the voltage by 1v ( 14.4 to 15.4) Unless you want to reduce the life of the batteries ....you will be charging them every 24 hrs .....it is not advised to go higher ....25 A is as much as you can push into every 100AH without damage.. |
#42
| Sterling supply a product that addresses the same issue. http://www.sterling-power.com/produc...tbatt-info.htm There are lots of solutions out there. Tony |
#43
| In the FAQ about batteries I agree with every word and for that link WitEver I will upgrade your rep ..!!! |
#44
I happen to believe that this page gives a more balanced review of the situation by someone who doesn't want to sell you an alternator controller. So maybe you should leave my rep where you believe it belongs ![]() Tony |
| Can you parallel two alternators? | IamBarry | Electrical Systems | 9 | 09-24-2009 11:45 PM |
| New Parallel Hybrid System | Iridiumworld | Hybrid | 8 | 11-14-2008 01:40 PM |
| New Parallel Hybrid System | Iridiumworld | Hybrid | 0 | 11-12-2008 03:56 AM |
| Batteries in Parallel | seanform | OnBoard Electronics & Controls | 6 | 04-27-2008 12:50 AM |
| charge 4 batt with three outputs? | dupsta | OnBoard Electronics & Controls | 1 | 04-09-2007 05:20 AM |
