Old 08-24-2011, 10:18 AM
darone1871 darone1871 is offline
outboard tank
i would like to fit a electric fuel sending unit to a honda outboard tank is it possible if so how can anyone help
Old 08-24-2011, 04:02 PM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
I don't see why it wouldn't be possible. The hard bit is mounting a suitable sized sender in the tank. The sender is effectively a variable resistor, and so you can measure the fluid level by making the sender the lower part of a potential divider and displaying the result. This is what fuel gauges actually do behind the scenes.
OpenPilot's ADC Widget can measure voltages (with a little hardware) for just this purpose.
Cheers,
Tim B.
Old 08-24-2011, 04:56 PM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
I am sure it could be done. But much better than a resistive unit (float on an arm type guage) I would use a capacitive or inductive unit. The electronics is solid state and completely sealed and much more accurate than the old resistive type. see WEMA USA http://www.wemausa.com/
Now for the downside. How are you going to ground this? If you are running wires to a gauge on the dash then the sender is part of your electrical system and needs to be grounded.
Also this means you will have to put a hole in the top of the tank so you will need to find a way to seal it with a gasket.
Why not buy a plastic tank that is translucent that you can actually see how much fluid is in it?
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 08-25-2011, 04:48 AM
Rep: 670 Posts: 2,457
That Norwegian WEMA gear that Ike pointed you towards is first class. Very reliable, but its not cheap
Old 08-25-2011, 05:07 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Wema is cheap, depends where you buy it...it is made in China you know.....and yes, it is very good.
Outboard Well vs. Slide for Outboard Mounting? CatBuilder Outboards 17 06-09-2011 07:07 PM
Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations Guest Powerboats 9 08-28-2007 03:54 AM
Converting water tank to Diesel tank steve vilah Boat Design 23 06-25-2007 07:13 AM
mounting outboard to inboard/outboard pcromien Powerboats 25 03-03-2007 11:46 AM
Bait tank/ holding tank fabrication question searaytuna Fiberglass and Composite Boat Building 20 11-17-2005 04:56 PM
