| OMC control box - convert push throttle to pull? Anyone know if this is possible? My mid-80's OMC control box PUSHES the throttle cable out, but the yamaha i need it to control needs the throttle to be PULLED. Ive seen where some yamaha control boxes have been modified to do this, both ways actually. Just wondered if anyone has done this or heard of this being done with an OMC box. Ive searched around for a while and talked to a few people with mixed results. I havent cracked open the box yet but i plan to soon. |
| Not sure about this specific setup, but when I built my last inboard, I found I could mount the controls and attach the cables so the cables exited the control head either in the fore or aft direction, and that controlled the "push or pull" of cable VS handles. Fortunately, both my throttle and transmission needed the same direction...
| I drilled the lever in my old Crysler control box to give the push or pull I wanted and the right travel ...have used it on a johnson Briggs and stratton and a yamaha without problem ...used old mercury cables from the boat yard scrap bin tooo I have seperate gear and throttle levers which makes it easier. |
| Your picture is too small for my old eyes, so I cannot read the part numbers. It is like this: The sleeve is held and the wire is moved, so it is pushed out. If you hold the wire and move the sleeve in the same direction, the wire is pulled in. Of course there are some minor modifications required. |
| After i get it taken apart ill let you guys know the prognosis.. I stripped out one screw after the other two came out without a hitch and had to stop there for now. Pist, you helped out on my other thread, i got it wired up and running fine, then ran into this problem. Where are all the haters that said i couldnt do it because i dont know anything about electronics, etc etc.. Ill update that thread when i get this problem tackled.. |
| DIY electronic throttle and gearbox control | CDK | OnBoard Electronics & Controls | 67 | 11-01-2011 03:55 AM |
| Cobra push pull for aluminum | rocket | Metal Boat Building | 2 | 11-18-2008 01:54 PM |
| FS: Control Cables/Push Pull Cables | GisMo | Marketplace | 1 | 08-13-2006 01:31 PM |
| 1969 Johnson 55 HP Throttle control? | bgull2 | Outboards | 1 | 06-22-2006 04:19 PM |
| Miller push-pull gun or 30A or 15A wanted | Jeffscarstrucks | Metal Boat Building | 0 | 10-21-2005 11:04 PM |
