| notebook computer as gps chart plotter on small boat Does anyone here use a notebook computer and software as a gps chartplotter on a small recreational boat? The nice big screen chartplotters are thousands of dollars, so I'm wondering if I could connect a gps to a notebook computer. Are notebooks hardy enough? Does pc software exist that is as good as the hardware chartplotters that can be had under $1000? |
| Yes too all your questions. We've used one for years. Some of the drawbacks are: size, may be too big for your boat; wires, they're everywhere unless yours has a real good battery; screens aren't usually bright enough for daylight use; screens are too bright for night use; cooling, overheating will shut them down.
__________________ Yours Aye! Rick M/V She:Kon Blog ~^~^~^^~^~^~^~^~^~^~^~~^~^~~^~^~^^~~^~^ "It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up! |
| Only thing new is little atom notebooks, many running on windows, about$300. They don't have cd roms but with big flash drive you could download charts to them. Also if your staying close to shore, consider Google earth has a nautical chart overlay. You can download area that you are going to be traveling to and then use little gps hookup to tell you location. All for under $500. But if you go far - take 2 gps, and paper charts. I still like paper charts next to me. In a pinch , I don't want to be fiddling with buttons. |
| I have 2 mini-itx form factor (smaller than 2 reams of paper) using this motherboard :- http://www.advantech.net.au/products..._1-2JKDYC.aspx - - - * AMD Turion™ 64 X2 mobile processor-AMD M690E * Two 200-pin SODIMMs, 4 GB DDR2 800 SDRAM * dual display for HDMI, LVDS * 8 serial ports )2 x ps2 & 6 x USB2+ 2 x DVD burners, - - 2 x 500G HDD, - - 2 x 1920x1080 23" diagonal widescreen monitors - easy to adjust brightness and contrast, run Linux OS & mapping software from Germany using data from a garmin 60, also links through HF & VHF as well as plays my music, movies, stores my videos & images.. and prints via a brother printer (my office) and runs on about the same power as a notebook and does not have those highly reflective notebook screens...
__________________ Try to be helpful... The trouble with people is to realise and remember that there are at least two sides for every story... A woman's breasts, one is not enough, - two may be just right, - but dreaming of 3 is a pleasant fantasy... |
| I have been using a Dell Inspirion laptop for several years. It sits on my chart table. The nav program is a cmap program that a friend gave me for working on his boat. I really like it. It is simple and easy to use. The charts are very accurate in the USA. It would show me in my slip when I was in San Diego. The charts for mexico are off a little bit but this is true of every nav program including the fancy, expensive chart plotters because they are all based upon the old paper charts. Don't let any slick willy salesman tell you otherwise because he's just blowing smoke. I use a Magellan 315 handheld GPS. It connects to the computer and receives external power through a cable that I purchased at Fry's Electronics in San Diego. You also need a serial port to usb adapter for my setup to connect the GPS to the laptop. I power the laptop with a 700 watt xantex inverter. The program has different screen settings for day, dusk, twilight and night. At night I mostly use the twilight setting because the night setting is too dark. Hope this helps you out. Chuck S/V Hale Moana |
| Thanks for the info because i will be doing the same thing very soon Quote:
i have been up and down the entire menu on the left bottom of the page nl. Primary database and looked at the whole lot eg. weather - ocean etc. but no nautical chart ? also tools but still no luck ![]() |
| Thanks all. I'm intrigued by the idea of using google earth - I see it has a realtime gps connect option and I see I can download the noaa charts for free in raster format from http://ocsdata.ncd.noaa.gov/ChartSer...x.jsp?type=BSB - I don't know how to do anything with these file formats however. I found http://www.csc.noaa.gov/crs/chartreproj.html which will take the bsb .kap file and export it to a tiff which google earth can overlay, but I can only see how to do this one by one. And then it appears I need to enter the coordinate data for each small section individually into google earth. Is there a much easier way? |
| Here are some sites for those who would consider Linux for its inherant robustness and NO Virus OS which for non-commercial users is free and downloadable... http://tuxmobil.org/linux_gps_naviga...lications.html for resources and links http://www.gpsdrive.de/index.shtml My current favourite http://www.ncc.up.pt/gpsman/gpsman.html http://www.mgix.com/gps3d/?download holds promise but seems to have gone quiet? http://www.tegmento.org/gpsylon/ more resources... There is also a thread in boatdesign.net that uses sourceforgenet as a home...
| Google earth is a great tool. I use it all the time particularly to check out anchorages that I have not been to. You can look straight down and you can tilt the view so that you get a feel for what you will see as you enter the anchorage. I do not integrate it into my nav program and don't know if I even could. But I have put in way points a couple of times and it gives you an idea of features on land that you might be able to use as range marks and the lay of the land/sea. It is just another tool to use along with all your other navigation tools. |
| http://demo.geogarage.com/noaa/ has overlaid the noaa charts on google maps, but I don't see any option to get this into google earth. http://earthnc.com/online is interesting in showing rocks, buoys, lights, etc. -- but noaa raster depth charts cost $35 per region. Are there other cool options out there? |
| we used nobeltec admiral 7 , way over top for small boat, but voted best nav software years in a row I once stood on beach in Turkey with magellan 315, , when I put the position on google earth was 15 miles inland , google earth tells you not to use for navigation |
| I have used all kinds of mixtures of PC's and dedicted equipment, and with the sole limitation that computers are not normally weather proof they are much better than the custom hardware for almost everything. I have been using an Apple laptop for years, and currently designing a ystem based around a 24" Imac. Basically the Imac will be running a copy of MacENC (http://www.navsoftware.com/marine-na...FWNM5QodSHYhFw) and I plan on having an ipod touch running INavX which ties into it. This will allow me to run everything from the auto pilot to the chart plotter from the ipod through WiFi. Plus by putting the computer downstairs I can protect it from water by flush mounting it behind a piece of lexan. The real advantages though are that since you now have a 24" screen you can dispose of the TV, and still keep all of the functionality of a full fledged desktop. All at a price of around $2K. As for the software... I have used all of this stuff, and it is probably the easiest to use piece of nav data around. Plus, since you get the charts for free from NOAA it makes it very easy to keep them updated, even for areas where you don't travel often. Heck if you get a Cellular card and cellular repeater for it you can even get relatively cheap internet within 20 miles of shore for about $100 a month.
| Stumble, I wish, - - that service following the coastline to 20 miles out - "Only in America" - rest of the world - ??? in SW Pacific not much luck - satellite at 10 + times that.... But the Apple offering is mighty attractive but more than double that here in Australia.... mine is about AU$1400 with 2 screens (US$1000)
| thanks for the input guys i have got a lot to learn now but Google Earth 5 is by far the smartest toy in my library now - the possibilities are endless with all the other downloads for us in a 3rd world country this is like heaven we battle to get paper charts if you wanted to leave now you could wait a month or two for a paper chart to Mauritius and it would cost an arm and a leg - even second hand is a bitch with our weak currency electronic charts are simply out of the question so yeah this kind of thing is like a gift from heaven when you are not in the civilised world ![]() |
stu |
| Computer Requirements for Boat Design | Konaphil | General Computing | 19 | 09-25-2008 09:33 AM |
| computer boat design | stan r | Boat Design | 4 | 11-16-2007 07:44 AM |
| Boat Intelligent GPS Navigation and Video Monitor System | waveless | Boat Design | 34 | 02-18-2006 03:32 AM |
| notebook specs for running CFD codes | sasidhar | Boat Design | 10 | 07-25-2005 08:31 PM |
| Chart Plotter Location | Lew Morris | Sailboats | 3 | 03-22-2004 12:59 PM |
