| nmea 0183 output from gps help Hi, just a question regarding nmea output strings from my gps unit. I have a jrc gps/sounder combo and I have connected a multi data repeater to it. this displays speed/ depth and temp. have sorted out the speed and temp all works fine but the temp doesn't display properly. my output string from the gps for temp is '$INMTW,+20.8,C*35 the repeater reads something completely different. I was just wondering if most temp output strings on other units have a '+' or '-' before the numerical temp value. the manufacturer of the repeater says this + is wrong and the repeater can't read it properly. Is this true or shall I return the repeater and but another brand. Or is there anyway I can change the data string output so there is no '+' in the string. any help much appreciated. cheers |
| This website http://www.maperl.com/Hydrography/ shows other $INMTW sentences without the '+'. It is possible that the GPS manufacturer's interpretation of the standard varied from other people's. However, no NMEA parser should struggle with a +/-, so it does seem that the manufacturer of the repeater is being rather unhelpful. Alternatively, you can use openPilot to read your NMEA stream, then with a few additions to the code you can make it output a new NMEA string without the '+'. You can also use it to display your position (when I've finished re-writing the plotting!), provide track/heading, satellite details, time, speed, temperature, and pretty much anything else you can think of. Cheers, Tim B.
| Wireless communication between GPS-unit on dinghy, GPS-unit on bouye and watch? | MrSantiago | OnBoard Electronics & Controls | 14 | 10-01-2009 02:14 PM |
| Collecting GPS & TackTick NMEA to a USB or Flash | awaysailing | Software | 4 | 06-24-2009 07:38 PM |
| How to Link NMEA from GPS To RS232 ON PC | rich99uk | OnBoard Electronics & Controls | 10 | 01-16-2009 03:04 AM |
| Cruzpro NMEA to computer -trouble | 40 Fathom Andy | OnBoard Electronics & Controls | 10 | 10-29-2007 09:33 AM |
| NMEA 2000 analog interface | DDW | Boat Design | 0 | 09-27-2005 12:49 AM |
